Is my IAT too high? Do in need a better intercooler?
My car is only making 6lbs of boost and is primarily driven on the street.
Anyway, I have the stock ATI air to air intercooler on my car - the single unit that mounts underneath the engine in the front.
I ran a data log during my street and dyno runs after I finished my recent build.
At the dyno my IATs were ~140F for each run.
On the street my IATs were ~175F for each run.
How does this compare to other people out there? Too high?
Do I need a better intercooler? If so, which one?
(PS - I have also heard that the stock ATI intercooler loses 2-3lbs of boost! Maybe I can get a few lbs back with a better intercooler?)
I'd say go for it but you could do it for about one-third to half the price if you can do it yourself compared to the EPP kit. The EPP kit is very nice, don't get me wrong. The finish is professional looking and the fit is perfect as you would expect and the work is already done for you so it can be bolted on in a day but if you could stand to save a few pennies and be proud of doing it yourself and you have a couple week to order it, fab it, weld it, paint it or polish it and install it then you could also go that route.... lol, maybe you should just buy the kit, that sounds like a lot of work, lol, especially in prime car driving weather.
I have heard the car will make more power just with a cooler IAT, without even changing the tune.
Just curious....Do you have a 2 core IC or a 3 core?
The specs are on this site
http://www.procharger.com/intercoolers.shtml
Meth injection has shown cooler IAT's in a lot of cases more so than intercoolers. I know more than a few guys who gain more boost by not running any kind of intercooler and just running meth injection. If you plan on running more than 12#'s of boost though, I would reccomend both a larger intercooler and meth injection.
Either way, you definatly need something to cool your IAT's before you run into issues. This is to say nothing of the benefits that running cooler IAT's will give you.
Then people say hard on an engine with high temps, newer engines are made to run higher I know the cooler the air the more power but the hotter the air more efficent it seems that most people view what is best for a race car not a street driven car which most of the cars are. Most people eliminate their EGR system to me egr doesnt hurt it helps in a street car if setup right can make power also just my opition I know I may be jumping aroung here.
If the correct air fuel ratio and timing is correct and many many other table to offset what the computer see for the IAT being around the 140 couldnt tell you if that is bad or good. But can tell you one thing if tuned right I have not seen detenation with those temp yet, I have alot of trial and error on the dyno testing as I have my own chassis dyno which allows me to test differant case's and compare things like this on differant cars and help my freinds that have daily drivers that also run them at the track.
This is a great question, as it can lead into the boiling point of the fuel as it sits on the valve before opening and does it also affect wall film transfer because of the extra heat. HOPE SOMEONE CHIMS IN and give a great example, egr, high temps, and IAT temps intrigue me. As most on hear are learning alot every day, Just my thoughts on it.
This car is primarily street driven.
I don't really want to go down the methanol/water injection path.
I plan on changing to a D1SC and running ~12lbs in the next year - so I think I need to get my cooling issue under control before I increase my boost.
I would like to avoid having to do a lot of work to install the new intercooler (like taking the nose off...) - simplest solution with best results is my desire. I do all the work on my car myself....but have 3 projects going right now so would like to minimize the total work involved to get decent results for this project.
