700 Rwhp??
Old Jun 19, 2008 | 01:25 PM
02LS1z's Avatar
Default 700 Rwhp??
I am trying to figure out everything that I will need to reach 700 rwhp and i have a few questions on how to get there. I have a D1SC head unit with the 8 rib sdce setup. I am getting ready to start to build my 346 to a 347 forged motor. Here are the things that I need help with
At this horsepower goal will I push water with ls6 heads and is this a bad thing(new to forced induction).
what compresion ratio should I run
I am planning on running a 04 z06 cam, will this cam get me to my goals or should i go bigger
last, what would I need to do for fuel setup. I have read the setup with the twin in tank pumps but i didnt understand what was used to activate the second pump. I am guessing there is a controller that when it senses boost it turns it on?
Any help you can give will be extremly appreciated
Thanks in advance
Adam
Old Jun 19, 2008 | 01:40 PM
98Z28MASS's Avatar
You shouldnt push water with good gaskets, head bolts, and a good tune so at 700 rwhp you should be ok, and pushing water is not a good thing as it usually signifies a blown head gasket or the fact that your detonating and lifting the heads, which is bad. As for compression ration id aim for around 9.0:1. The z06 cam is a good FI cam but you could certainly go bigger to gain some extra power, it just depends on if you mind having a slightly choppy idle which comes with a larger cam. With a small cam though its going to take more boost to hit your goal. As for a fuel setup the dual walboros should work as plenty of people are running that setup. Not sure on the switch though. A full forged 347 with a d1sc is certainly capable of hitting the numbers you want so goodluck with the build and keep us updated!
Old Jun 19, 2008 | 01:42 PM
BLNLS1/RX7's Avatar
The best person in North America to help you with an honest answere is Bob at Exotic Performance Plus.com. They have built a lot of motors with the RWHP you are looking for.
Old Jun 19, 2008 | 02:02 PM
02LS1z's Avatar
Yes that is true, I ordered my 9 inch from bob and he was very helpful with that. So Bob what do you think? Thanks for your input 98z, yea so i def dont want to be pushing any water!
Old Jun 19, 2008 | 08:00 PM
ZDOG's Avatar
subscribing
im into my build now. looking for close to the same power. im doing a 364 and trying to pick i cam and stay with it is a s.o.b.!
Old Jun 19, 2008 | 09:58 PM
02LS1z's Avatar
yes i agree, it looks like i am going to probally have to sell my z06 cam to reach my goals so any cam suggestions would also be great!
Old Jun 19, 2008 | 10:13 PM
sevanseriesta's Avatar
be interested to find out what head gaskets you guys recommend for that horsepower
Old Jun 19, 2008 | 10:29 PM
cookba's Avatar
we have a similar plan in the works. But as my car is a DD i am doing a little more for security of my purchase aka reliability and drivability BUT leaving it open for the future big power plan. What i got down so far is:
HKE forged 403
AFR 205cc
Tony Mamo ported FAST 92 with NW 92mm TB
Custom grind 224/228
EPP D1SC kit, prob run 8-10psi
Old Jun 20, 2008 | 05:09 AM
EPP's Avatar
EPP
Default Thanks guys!
Thanks in advance
Adam
At this horsepower goal will I push water with ls6 heads and is this a bad thing(new to forced induction). No, it shouldn't be a problem.
what compresion ratio should I run 9.5/1 is what we shoot for.
I am planning on running a 04 z06 cam, will this cam get me to my goals or should i go bigger It will get you there.
last, what would I need to do for fuel setup. I have read the setup with the twin in tank pumps but i didnt understand what was used to activate the second pump. I am guessing there is a controller that when it senses boost it turns it on? You can run both pumps all the time. We have been doing it for years without any problems. This eliminates potential problems that can be created if the second pump does not turn on. I strongly suggest a fuel pressure gauge be installed so that fuel pressure can be monitored.
Check out this build, which closely resembles yours.
http://www.exoticperformanceplus.com...Car.php?car=40 Bob
Old Jun 20, 2008 | 09:33 AM
Bob, there are so many people out there that say that running both pumps at the same time is not good. They say that the heat is the main problem. I am not sure personally I run a double walbro, but I have it set on a hobbs switch. Do you guys do anything different for the heat issues with the fuel pump
Old Jun 20, 2008 | 09:51 AM
Superman09's Avatar
LS1Tech Sponsor
You will need a full fuel system for this power level as well. The dual pumps along with 60# injectors, upgraded rails, front mount boost referenced regulator, return line. I am about at the max of dual pumps and 60# injectors with nothing else and thats 670 rwhp with TT.
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Jun 20, 2008 | 10:11 AM
EPP's Avatar
EPP
We have not seen a problem with heat with both pumps being run, if there was a problem it would show up after an extended trip when you go to restart the car. Possibly others have had problems that we just haven't run into.
We have seen what happens though when a hobbs switch fails. lol Bob
Old Jun 20, 2008 | 10:38 AM
Superman09's Avatar
LS1Tech Sponsor
i drove home 300 miles from EPP and had no issues....
__________________
Old Jun 20, 2008 | 11:40 AM
02LS1z's Avatar
Well i guess i can start ordering parts, i see that you used a gt2-3 cam on the vette should i use this cam too? I like the sound of a lope with supercharger whine for sure!
Old Jun 20, 2008 | 12:19 PM
EPP's Avatar
EPP
The GT2-3 camshaft has no lope at all. If you want a nice sounding lope, our blower camshaft will give you the sound you are looking for. It is shown here.
http://www.exoticperformanceplus.com....html?item=679 Bob
Old Jun 20, 2008 | 12:30 PM
02LS1z's Avatar
That sounds great, how is the drivability? I have a tourqer 3 right now and im not looking for something that would be compared to it, so if that cam is more streetable then it may just be the cam for me!!
Old Jun 20, 2008 | 02:29 PM
EPP's Avatar
EPP
Thumbs up
This cam is very streetable, we have it in the Caddy CTS-V and it runs great. http://www.exoticperformanceplus.com...Car.php?car=29
Here is a video clip of it in a camaro with an STS turbo that we built.
http://s81.photobucket.com/albums/j2...MOV00004-1.flv
Here is a video clip of our cam in KP's T/A.
http://www.exoticperformanceplus.com...html?item=1109 Bob
Old Jun 20, 2008 | 05:33 PM
02LS1z's Avatar
I will be giving you a call on monday bob, i need a balancer the cam and some lifters! Also I need to get a quote on some rotating assembly.
Old Jun 20, 2008 | 05:37 PM
EPP's Avatar
EPP
Thumbs up
Thanks, talk to you then! Bob
Old Jun 21, 2008 | 12:14 AM
02LS1z's Avatar
anybody have problems with the hat on the blower on a f-body setup, it seems like it hurts the output of the blower. Is there any different setups available?
