Day 1 Build Ebay Kit
Old Sep 23, 2008 | 03:12 PM
  #341
projectcam's Avatar
Originally Posted by fastls1inaz
Bump for numbers
Ill have my car running here soon Steve.
Old Sep 23, 2008 | 04:33 PM
  #342
Dean95z28's Avatar
I am getting started on mine, I started at the rear and am working my way forward. I have a stainless fuel cell with an intank aeromotive a1000, and all new suspension adj. LCA's, drag shocks, adj. T/A,. I am getting ready to drop the K member and start on the front, I am also running a LQ4 with my setup. I hope all goes well.
Old Sep 23, 2008 | 05:11 PM
  #343
Mean Green z28's Avatar
pretty decent kit and works pretty well. The only thing I may change is those two v-band clamps at the back, takes too much ground clearance. A simple slip fit with a bnad clamp would've worked better.
Old Sep 24, 2008 | 12:09 PM
  #344
Shockwave179's Avatar
Lot's of cool info here, good work.
Old Sep 29, 2008 | 11:19 PM
  #345
blazin's Avatar
Think you could get away with having everything coated instead of wrapping it?
Old Sep 30, 2008 | 09:54 AM
  #346
Frost's Avatar
My PTK kit is/was coated..... and NO. there is too much heat under the hood.
Old Sep 30, 2008 | 10:07 AM
  #347
Hennytime's Avatar
did you melt much stuff?
Old Sep 30, 2008 | 10:59 AM
  #348
Frost's Avatar
yes, even with piping wrapped there were heat issues to deal with...
Old Sep 30, 2008 | 07:39 PM
  #349
blazin's Avatar
What did u have the most problems with the ps lines and engine mount?
Old Oct 1, 2008 | 04:04 AM
  #350
red90cobra's Avatar
Originally Posted by projectcam
Those are the wrong sizes completley. If anyone orders this kit and needs the clamps, you need 6 3" clamps and two 3.5" clamps. I learned the hard and costly way.
Yeah the one on ebay is what this guy said. I learned the hard way on the two 3.5.
Old Oct 1, 2008 | 04:30 AM
  #351
red90cobra's Avatar
Btw do you have better pics of how close to the steering boot the dp gets? I got mine mocked up so far and seems like it's pretty close. Thanks
Old Oct 1, 2008 | 06:52 AM
  #352
98Camarod's Avatar
i guess im going to have to wait and see before i order my clamps then. monello said to order 2.5 and 3 inch clamps. that seems to a big difference to me
Old Oct 1, 2008 | 05:41 PM
  #353
98Camarod's Avatar
So who has the latest ebay kit and what size v band clamps did you use and where did you get them from?
Old Oct 1, 2008 | 05:58 PM
  #354
Pat-Man's Avatar
I thought the hot parts only kit comes with the clamps:
http://cgi.ebay.com/ebaymotors/Turbo...mZ330275917761
Old Oct 1, 2008 | 10:53 PM
  #355
red90cobra's Avatar
it comes with 6 clamps you need two extra ones for the downpipe. first to connect the turbo to the down pipe and the one after that. My kit that i got from them doesn't fit like pictured so far. lol. didn't think it would. The clearance to the steering rack boot is alot closer. Not sure if it's because of the turbo or what. I'll get pics when i got the turbo mounted got to go buy some bolts.
Old Oct 1, 2008 | 10:58 PM
  #356
red90cobra's Avatar
Oh yeah where did you buy the power steering stuff local or did you order it? And how is it connected on the bottom side to the rack? Are you still using the stock low pressure side of the power steering line?
Old Oct 1, 2008 | 11:53 PM
  #357
Rickys S/C Z28's Avatar
any numbers yet?
Old Oct 5, 2008 | 05:10 PM
  #358
98Camarod's Avatar
Any way we can get some pics of the cold pipe installed and some more wastegate pictures?
Old Oct 10, 2008 | 10:06 PM
  #359
59 camaro's Avatar
nice work man....took me a good half hour to read but it was worth it
Old Oct 10, 2008 | 11:01 PM
  #360
Monello's Avatar
Here is the link to all my pics.
http://s303.photobucket.com/albums/nn151/monello96/
