Twin 76 build.
Old Jun 25, 2008 | 08:17 AM
sevanseriesta's Avatar
Will do!
Old Jun 25, 2008 | 07:35 PM
TopFlite's Avatar
Nice selection of parts. Are you going true duals or keeping the exhaust dumped?
Old Jun 25, 2008 | 08:27 PM
I have not though much more about the exhuast other than, It will be 4" all the way back. That is about the best that I can do for you. But I can guarantee that it will not be duals cause both turbos go into 1 pipe!
Old Jun 25, 2008 | 08:39 PM
ls2 bait's Avatar
i see now reason why it wouldnt spool. **** mustangs run that **** all the time and they are all under 346 c.i
Old Jun 26, 2008 | 06:29 AM
CamTom12's Avatar
Originally Posted by sevanseriesta
LOL, Man I have not seen you in a long time. I can not believe that you remember my screen name. No We moved into a house about 3 years ago.
That's cool man.
Yeah, that 9-inch worked great until I broke the locker, then after I replaced that it worked great again. I sold it to a guy in my local car-club to buy my wife's engagement ring, hahaha.
What's your HP goal on this set-up?
Old Jun 26, 2008 | 06:33 AM
Minimum 900, this kit should be able to make much, much more then that though. I am going to get everything Ironed out with the 347 and then move up to bigger after that. I am looking 9's for right now.
Old Jun 30, 2008 | 09:37 AM
Update...
Today I received my block back, Fresh bore, and cleaned. I also got in my new Gm MLS 5 layer head gaskets, My Abs Delete Kit.
I am waiting on my Total seal rings, and Clevite race bearings to come in. They should both be here today. I am also waiting on my Spohn Solid Motor mounts I have not heard anything about those yet. I received my ArtCar 700r4 Transmission and Stall On Friday. I am still waiting on My truck manifolds not sure when those will be here!
Old Jul 2, 2008 | 05:15 PM
Yesterday I mocked everything up on the block. I was told that it would fit on a stock k-member, but that was not the case. Glad I did mock it I would have been upset. Anyway here are some pics of what it looks like mocked up. Everything goes together very easy.
I also received my injectors today but they are the wrong ones so I have to send them back. Friday, Saturday, and Sunday I will get lots done. This is the first vacation that I will have in over 2 years..... Thank God
Old Jul 3, 2008 | 01:49 PM
Wicked 1's Avatar
looks good cant wait to see
(Built 700r4 Turbo 3500 stall)
let me know oh it holds up
are you going to come to track day at great bend 8/9/08 going to see what the twin firehawk can do with the th 400 and slick and 16 psi my be 100 shot to i hope the mid to low 9s
Old Jul 3, 2008 | 02:25 PM
I didn't know anything about it. I might, we will have to see if I have everything Ironed out by then and I didn't already blow it up.
Old Jul 3, 2008 | 03:19 PM
venom ws7's Avatar
Very nice the Turbo setup look awesome.
What H/C/I will you use???
Good luck with the rest of the build.
Old Jul 3, 2008 | 03:54 PM
  #32
I am going to be using a comp 228/228 .588/.588 @ 115 , I also have some massaged 317's with dual PRC's, and the Intake that I am going to try first is a Ported PP 75mm Intake (Typhoon), These are all parts that I have had for sometime, things will be different with a different motor though!
Old Jul 18, 2008 | 09:54 AM
  #33
Default Update with pics
Well here are some pics of what has been done so far. When I take the motor back out I will get some better pics of what had to be cut. I had to notch the frame on both sides, may not have had to do as much if I would have installed the solid motor mounts first but that is no big deal.
Solid motor mounts were installed
K-Member was notched on the passenger side front
Passenger side front frame notched
Driver side frame notched
Intercooler piping routed and installed
Turbos and piping installed.
Here we go!
turbos and hot side fully installed
Side view of everything fully installed
Drivers side view of installed
Drivers side frame notched
Passenger side solid motor mount (can now fit a 4"DP no problem)
Drivers side solid motor mount
Radiator in place
Passenger side notch in the frame
Front view on intercooler in radiator installed
Old Jul 18, 2008 | 11:29 AM
  #34
Josh@KY-Turbo's Avatar
I am gonna send ya a Link to a store that sell the 3" to 2.5" Transistion 90* elbows. Not real expensive and will seal better on the Turbo's.
Old Jul 18, 2008 | 12:57 PM
  #35
well the intercooler is 2.5" inlets so I am not going to go 2.5 to 3 to 2.5. I am going to call them though and get a 2.5 90 4ply. For better sealing thats for sure. I also need a 3" transition to the throttle body so I will get one of those from them also!
Thanks for the help!
Old Jul 18, 2008 | 01:43 PM
  #36
No problem.
Old Jul 18, 2008 | 01:59 PM
  #37
toxik iroc's Avatar
Old Jul 18, 2008 | 03:21 PM
  #38
toxik, no looks good, looks terrible, or anything of that sort just dots huh.....
Old Jul 18, 2008 | 04:14 PM
  #39
BlazinT/A's Avatar
i think it looks sexy as all hell
Old Jul 18, 2008 | 04:48 PM
  #40
I take criticism very well so you guys can also tell me what you do not like, I would like to try an make things better also....
