High HP Guys Not Using BS3 - Knock Sensor Question
Any help is appreciated.
Thanks,
Cody B.
Seriously though...It can fit in there with the supplied J bracket from Procharger. The thing is though, fitment of the air cleaner for daily driving is tough to get on...but if you're going strip only w/no cleaner...no prob.
i bet w2w was running a lot of crankcase vacuum and is why they needed to be sealed up.
also no knock control with bs3 is standard, but i have run knock control on mine for a while as well.
I don't plan on running a sealed crankcase, so as long as I have a good vent elsewhere that isn't causing restrictions enough to put a load on the knock sensor seals, I should be good.
Will a dry sump setup pull enough vacuum on the bottom side of the crankcase with the scavenge lines to cause any issues? I don't plan on running a vacuum pump like Kurt mentioned, but I will probably go to a dry sump setup once I decide to turn more RPM's.
