VIDEO of Superchargered F-Body by MTI Racing
Old 07-02-2008, 06:48 PM
Blackbird's Avatar
looks like they have an exhaust leak and that's some of the explosion from the backfire that coincides with seeing the spark / flame popping out from under the car.
Old 07-02-2008, 08:36 PM
WS6HUMMER's Avatar
Looks really nice!
Old 07-02-2008, 08:53 PM
THROTTLEJUNKIES's Avatar
Seems like a pretty nice setup. Id still like to know what the numbers look like on a H/C/I, etc. type fbody. Since not very many people on this board have stock cars. 6K for the it seems pretty fair, but 2K for the install....DAMN! I guess your SOL if you dont know how to do it yourself.
Old 07-02-2008, 10:48 PM
TBaGZ's Avatar
if you watch when it sparks a puff of smoke comes out the back.
Old 07-03-2008, 09:49 AM
Stephen@MTI Racing's Avatar
Default Mystery Spark
I see the spark!
The only thing that can throw the spark FORWARD is the spinning rear tire.
As a matter of fact, I've seen wheel weights go airborne, small rocks from sticky tires, etc... That is why you don't stand behind the dyno.
It was probably a small pebble from our landscaping just outside that baydoor.
By the way, here's the WIDE power graph...
464hp to the tires. 450 torque starts at 2500rpms and peaks at 475. (No headers. Stock engine. Stock air cleaner.) If you have mods already done to your car, results may be higher.
We'll upload some burnout video soon.
Supercharger systems are ready for order.
Old 07-03-2008, 10:28 AM
Pinky93's Avatar
Very nice, I am looking foward to seeing this system in person!
Old 07-03-2008, 11:38 AM
Intercooler2's Avatar
Looks nice and all just IMO too expensive. If it was in the 3k range they would sell like crazy but you can make most of that gain up with other parts, easier and for less money.
Old 07-03-2008, 01:17 PM
Ashes's Avatar
Wait, you can get into the high 400s at the wheels for less then 6k? Granted it is 8k if they do the install too but I am assuming that you'd be doing the installs yourself (be it supercharger or heads/cam). I haven't seen any car here spend less and get the same results. Wouldn't your reason for saying it'd sell like crazy if it was 3k would be that 3k for mid-high 400rwph would be an insanely good deal. Sry bout off being off topic.
No matter though, I think it looks awesome. Given I had the money, I wouldn't even have to think about it. To MTI, anything you can add about fueling on the car above? Was the stock fuelpump/injectors enough to feed that power level?
Old 07-03-2008, 02:33 PM
30th t/a's Avatar
how much boost & power can this supercharger make on a built bottom end 347?
Old 07-03-2008, 03:20 PM
Killer_Z's Avatar
god i love the whine of a maggie. its awsome.
Old 07-03-2008, 03:29 PM
Black C5 Z06's Avatar
The first 10 people are SOL anyway because the first post said you HAVE to let them install it if you are one of the first 10 people.
Old 07-03-2008, 03:58 PM
  #32
In the world of performance products, you can figure a cost of approximately $100 per 1 hp. Our MTI Racing supercharger system is a relative "no brainer".
The system includes the injectors. It uses the "Magnavolt" in combination with the stock fuel pump.
Old 07-03-2008, 04:01 PM
  #33
98catfish's Avatar
I dont get the problem w/ mti installing the first 10 kits, It only improves the kit. By installing the first 10 they will be able to identify ANY problems w/ different scenarios. any clearance issues due to worn out parts like motor mounts. it will just make it better for those who want to do it theirselves.
Doug
Old 07-03-2008, 04:09 PM
  #34
SPRAYED 01's Avatar
Thats not a bad deal with injectors. To do a heads/cam/intake and full bolt on car would be right around there and be maxed completly. This kit with bolts on would make over 500hp and have no drivability problems.
Old 07-03-2008, 04:35 PM
  #35
98catfish's Avatar
Absolutely!^^^^^^^
This is a intercooled 122 s/c with injectors and all supporting mods needed to make this fit in a car that was not designed to have a blower added.
For a drag racing application is there something better...absolutely! For a street car probably not? contrary to popular belief most of the guys on this forum dont go to the track more than 2 or 3 times a season. They just want a fast street car and this is IMO the best way to go.
If you want to bitch about the price look at it this way, If you have a fast intake now you will save about 1200.00 because you will no longer need it. If you have an ls6 you'll save about 400.00 If you already have an upgraded fuel system and can tune yourself you will be able to save a lot more.For all you get w/ this kit it is a damn good deal.
Doug
Old 07-03-2008, 05:02 PM
  #36
400?
A 325 RWHP car and 125 HP shot of NOS. What is that... $600?
Old 07-03-2008, 06:36 PM
  #37
ninetres's Avatar
Not impressed with the poppage! I'd like to see this kit on a mildly modded car @ ~8psi. There are several turbo kits making well more than 600whp for the same price.
Old 07-03-2008, 07:16 PM
  #38
ramairroughneck's Avatar
What kind of throttlebody is that? Is it included in the kit?
Old 07-03-2008, 07:51 PM
  #39
98catfish's Avatar
Heres mine 505/500 stock motor w/ headers and exhaust 8#s
It would be close to 600 w/ heads and cam!
BTW no popping here! I believe they were working on the wot tune first as this is a sd tune.
Old 07-03-2008, 08:31 PM
  #40
sidewayz28's Avatar
Originally Posted by Ashes
Wait, you can get into the high 400s at the wheels for less then 6k??
Quick Reply: VIDEO of Superchargered F-Body by MTI Racing
