i got a FI Comp Cam and have a quick question
Old Jul 13, 2008 | 11:49 AM
presto_z's Avatar
Default i got a FI Comp Cam and have a quick question
i got a used low mileage comp cam for free and was told it would be a good FI cam
im a stalled auto (3600vig, 4l60e)
and will be running 6-8lbs of boost
my question is would this cam be worth putting in?? if not im not going to cam it out.
here is the spec sheet
Serial # D 6068-04 Spec Card# 06930104
Part # 54-000-11 CAMSHAFT, LS1 CHEVY LS1/GEN III '97-UP
Core C54-11H CAMSHAFT BLANK, LS1 1997 UP 5.7 CORVETTE
Grind # LS1 3724R /3726R HR112+4
DURATION @ .050 INTAKE 228 ROCKER ARM RATIO
VALVE ADJ INTAKE .000 DURATION @ .050 EXHAUST 232 INTAKE 1.70
VALVE ADJ EXHAUST .000 LOBE LIFT INTAKE .3460 EXHAUST 1.70
VALVE LIFT INTAKE .588 LOBE LIFT EXHAUST .3500
VALVE LIFT EXHAUST .595 LOBE SEPARATION 112.0
DURATION .006 INTAKE C/L 108.0
TAPPET LIFT INTAKE 277 CAM ADVANCE 4
TAPPET LIFT EXHAUST 281 HYDRAULIC Y
VALVE TIMING .050 OVERHEAD CAM N
VALVE OPEN INTAKE 6 JOURNAL DIAMETER STD 2.165
VALVE OPEN EXHAUST 52 RECOMMENDED VALVE SPRINGS
VALVE CLOSED INTAKE 42 DEPARTMENT P
VALVE CLOSED EXHAUST 0 SPC INSTR FOR CUSTOMER
any input would be great
Old Jul 13, 2008 | 12:09 PM
Floader's Avatar
it would help to know what kind of blower you have (turbo? centri?).... But as a rule cams of almost any sort work damn good on FI applications.
Old Jul 13, 2008 | 12:14 PM
52172's Avatar
He's got a single turbo off ebay. It will work, it will bleed off some boost, but will work fine.
Old Jul 13, 2008 | 12:18 PM
presto_z's Avatar
its the PTK clone turbo kit (from ebay) and am looking for 500rwhp or 8lbs of boost whatever one comes first
Old Jul 13, 2008 | 12:29 PM
Floader's Avatar
i am making 566rwhp at 8-9 PSI with a cam of about that size, so just stick the thing in there and be happy. besides the cams sound cool.
Old Jul 13, 2008 | 12:36 PM
presto_z's Avatar
in your sig it says "the wrong cam".. may i ask why???
Old Jul 13, 2008 | 01:31 PM
bboyferal's Avatar
LSA seems a little low...Too much overlap bleeds some boost...
Many would recommend at least a 114 probably. I myself run a 116.
Old Jul 13, 2008 | 01:57 PM
deadmanTA's Avatar
It's a good size and will make more power, but that lsa is low. You can always try it and if you don't like it change later on down the road or sell/trade it.
Old Jul 13, 2008 | 04:01 PM
Jake@EPP's Avatar
Thats some damn good power for a stock motor and 8psi.
It may not show as much boost as a cam with zero overlap, but with a blower you have some of the airflow (as you say bleeding off boost) that clears the cylinder. This is a common misconception, just about any cam will work with a centri.
Since turbos have backpressure it needs to spec'd a tad different.
Old Jul 13, 2008 | 07:26 PM
Floader's Avatar
My cam is "wrong" because some people might say its to big for a blower car... but it seems to work good for me and it was cheep. There a probably better cams, but its a cost vs. performance thing.... if you already have the thing put it in, it will def. make more power than a stock one.
500+ cars on street tires are really kinda silly anyways..... If one cam is down 15rwhp vs. another is it really a big deal?
Old Jul 13, 2008 | 07:31 PM
Jake@EPP's Avatar
I dont see anything wrong, it makes good power for what it is. Dont listen to bench racers lol, take that thing to the track and run it.
