aps vids
Old Jul 26, 2008 | 12:09 PM
todd4168's Avatar
Default aps vids
Been away a while didnt know how many of you have your aps kits up and running? Also is there any street vids out there yet? thanks
Old Jul 26, 2008 | 01:55 PM
CALL911's Avatar
Here's a video of one of the first APS Twin Turbo C5's vs my old 13 year old LT1
Supercharged Z28 vs Twin Turbo C5
Old Jul 27, 2008 | 03:38 AM
LilJayV10's Avatar
That vette got walked.
Old Jul 27, 2008 | 08:30 AM
todd4168's Avatar
horrible
Old Jul 27, 2008 | 09:41 AM
CALL911's Avatar
Originally Posted by todd4168
horrible
Thats what he thought . To be fair, the Z28 has more HP than the Vette did. There's always someone faster out there.
Old Jul 27, 2008 | 01:04 PM
LilJayV10's Avatar
Obviously
Old Jul 28, 2008 | 08:55 PM
Darren P's Avatar
this is not the street but here you go
I got some results from the track today with my APS kit. went on the Dyno on Thursday night, my E-Boost ll craped out on me and I can only run off of the wastegates which made a rock steady 8.5 PSI and it made 65x RWHP and 660 RWTQ. Went to the track today and ran a best pass of
60FT 1.465
1/8 6.486
MPH 107.237
I was pretty happy with it for the first time out
here is a video of that run
http://img532.imageshack.us/my.php?i...9130125cz1.flv
http://myspacetv.com/index.cfm?fusea...deoid=33981868
my combo is as follows
LS2 block, 403 CID, AFR 225 CNC heads 225, Compression ratio 8.5 to 1, 234/234 at .050 598/598 lift cam. APS twin turbo kit, Nasty performance stage 3 street system with Lonnies twin Racetronix in tank pumps, Racetronix 96 pound injectors, converter harness, and a AEM impedance converter. 4L80E transmission that I got on a swap here, supposedly a Rossler but is is not painted black so I don't know if it is built or not, it has a Vig stall converter, I was told by vig that it was between a 2500 and 3600 but I don't know for sure what it is. it has a Moser 9 inch rearend with a Detroit locker and a 3.50 gear, 35 spline axles, Full BMR K member, front upper and lower control arms, rear lower control arms, and Panhard bar, Spohn Torque arm with 2 drive shaft safety loops. Carolina powertrain 3 inch DOM steel drive shaft. BMR extream duty drag Sway bar, double diamond sub-frame connectors, and 1/2 of my own homeade 304 stainless steel true dual 3" exhaust. I am shifting at 6000 RPM but the transmission seems to be slipping on the 1-2 shift and on this pass I had it set to shift at 5000 RPM and it took it from there to 6800 to compleat the shift.
for only 8.5 pounds of boost I am pretty damn happy. I think it has another 2 tenth's if the tranny will shift correctly and it is still on the stock springs and shocks so I may have some more to pickup there. Will try to hit Rockingham in the next couple of weeks.[/
a few weeks later at Rockingham I ran a 10.20 at 132 with a 6.7 at 106 in the 1/8th but it was not hooking
Old Aug 14, 2008 | 01:28 PM
keliente's Avatar
I'm late on this thread but here's mine.
Old Aug 14, 2008 | 02:38 PM
ws6taguy's Avatar
here is a video of mine on the dyno
http://myspacetv.com/index.cfm?fusea...deoid=29387590
and one of it pulling on the dyno sorry i dont have any videos yet on the track
http://myspacetv.com/index.cfm?fusea...deoid=29389178
