Single T76 LT1 Just Back from the Dyno-
Color me very happy!
Max PSI : 12
Max RWTQ: 571
Max RWHP: 574
Engine
Displacement......: 355 ci
Heads.............: Stock LT1 Castings, ported by Will Garza
Fuel Injectors....: 60# Mototrons
Compression Ratio.: 8.8:1 Diamonds
Cam...............: Custom Bret Bauer Turbo Cam
Throttle Body.....: Stock 48mm
Intake Manifold...: Stock Lt1
Exhaust...........: Log Manifold, 3" pipe all the way back to 3" Dynomax Muffler
Machine work......: Jim Pitcher-Chatham, NY 12037
Fuel System
Stock intank
NOS Inline pump
Stock lines
Stock Fuel Pressure Regulator
Tuning
PCM Tuning........: Untouched Mail Order MAF tune by Bryan Herter @ PCM4Less
Transmission
Transmission......: Stock T56 Six Speed
Rear Gear ratio
Differential......: 4.10:1 Ford 8.8 w/GM 10 bolt 'legs'
Turbo Specifics
Turbo.............: TC 76 w/MPS Wheel .96 A/R(www.forcedinductions.com)
Intercooler.......: 3" OBX air to air, front mounted
Hotside...........: "RealQuick" log manifold system
Coldside..........: Ebay 3" Aluminum pipe/coupler/Tbolt kit
Water/Meth........: NO
Boost controller..: NO
Wastegate.........: TurboSmart 38mm w/14Psi springs
Blow off valve....: Tial 50mm w/11psi spring
Dyno Facility
SGP Racing - Veterans Memorial, Houston, TX
RPM/Boost/TQ/HP Measurements(I had him start at 3K)
3,000 = 05 psi = 400 = 240
3,250 = 06 psi = 370 = 245
3,500 = 07 psi = 400 = 260
3,750 = 08 psi = 425 = 320
4,000 = 10 psi = 465 = 355
4,250 = 11 psi = 500 = 400
4,500 = 12 psi = 571 = 475 (We think the Wastegate opened after this)
4,750 = 11 psi = 571 = 525
5,000 = 11 psi = 565 = 548
5,250 = 11 psi = 560 = 560
5,500 = 11 psi = 540 = 565
5,750 = 11 psi = 525 = 570
6,000 = 11 psi = 500 = 574
6,250 = 11 psi = 475 = 565
Air fuel Ratio was 11.x:1 during 3K to 6K, then briefly went to 12.x:1
Weather conditions at the time of dyno:
1pm today 97 degrees F, 40% humidity, 29.9 barometric Pressure, dew point 69F
Test was through full exhaust, no dumps/cutouts. Air filter on. At 12 psi during the first pull, the reducer coupler at the compressor outlet popped off. Dan took a break while I got under there to put the coupler back on with a good T-Bolt. To my horror, I saw the Air filter was GONE. I remembered hitting some retread crap the other day when the car in front of me just went over it and I didn't have time to react but I didn't consider it could have wacked that low slung air filter. I don't know how long I've been driving around, drinking dirt into my new wonderful motor, but it's been at least 2 days. I bought a 3" cast aluminum elbow I found in SGP Racings Box 'o pipes and put that on there. I was frustrated when SGP didn't have a 4" K&N filter but Dan had Moshi drive me over to Pep Boys to get one, free of charge.
With that all back on and buttoned up we took the second pull. The TQ/HP lines on the graph are sooo smooth. Not jittery or having spikes and dips. This is an untouched/altered mail order turbo tune! Good Job Bryan!
I asked Dan why it was that a wastegate with 14psi springs would open up at 12psi and he said he's sees it a lot with cars that don't have boost controllers. He recommended I get a Blitz electronic boost controller so I'm going to pick that up next paycheck!
Jon (aka "RealQuick"), good job on the hotside!
Great numbers out of that TC76 turbo and a mail order tune. Are you going to turn it up even further?
J
This dyno (Dynapack) is different than any dyno I've been on before. They take your wheels off and bolt on these splined yokes. Each side of the car has a dyno box that the splined wheels go into. The great thing about this is there's no wheel slip/spin like occastionally happens on a conventional drum. The operator said it's the best kind of dyno for tuning. I know the "Mustang" dyno numbers read low compared to a dynojet numbers for a given car but I didn't know if this brand of dyno I was on today was 'optimistic' or 'pessimistic'. Tiago said it's actually quite pessimistic and he felt that my numbers on a dynojet would be over 600. It sure felt good to hear that.
As far as it peaking early, it sure seems to have a lot of grunt right off the bat but on the street, once it's in 3rd or 4th and it gets a load on it and into the boost, it's flat wicked/evil
. I hope to get it to the 1/4mile tomorrow in (relatively) closeby Austin, Tx. Trending Topics
I would like to go 3.55's. Right now with the six speed, the 4.10s are still a fun factor and I can actually use 6th gear (55 mph at an indicated 1,600 RPM)
