Under piston cooling.
Old Feb 27, 2009 | 11:19 PM
Katech_Jason's Avatar
LS1TECH Sponsor
Originally Posted by GIGAPUNK
I know this thread is kinda old, just thought that I'd add for the sake of reference.
I was looking into these for my LS7 and was told by katech that they will not work on the LS7 block because of the location of the oil galleys. I ended up using oliver rods with lube tubes, as I plan on running a bit of crankcase vacuum in a road race engine.
What did I say? Piston squirters can be used in any Gen 4 block. LS9 squirters will work in shorter stroke engines, our squirter will work for 4" stroke engines.
Old Jan 23, 2010 | 06:19 PM
pdasterly's Avatar
anyone have a correct machining print for these?
Old Jan 23, 2010 | 06:43 PM
speedracer5532's Avatar
Call Jason @ Katech and he can email you the print.
Old Jan 23, 2010 | 06:45 PM
CarsandWomen's Avatar
how much would having a block machined for these cost? never thought id see it with anything other than race motors
Old Jan 23, 2010 | 06:58 PM
I feel I got a deal on the machine work for mine...$300. I would probably guess about $500. You can't just machine the block and bolt them in and be done. Clearances are very tight with a 4 inch crank. Basically you have to mock up each one and modify things until everything clears.
Old Jan 25, 2010 | 09:59 AM
pdasterly's Avatar
katech isn't going to just give me the machining print
Old Jan 25, 2010 | 05:19 PM
TT350's Avatar
I done my old school sbc, pic's on page2.
http://www.theturboforums.com/smf/in...opic=126172.25
Old Jan 25, 2010 | 07:45 PM
DeltaT's Avatar
TT350, good info, nice job.
Jim
