SDCE tensioner setup and power steering cooler
Ok I have the SDCE kit on my prochrager set up and I also have a second radiator fan the 9in one that EPP sells. anyways it is a major PITA to work that tensioner without removing my fans. I was thinking if I could relocate my Power steering cooler I would be able to work it with out removing my fans. has anyone done this and what hose have you used for the upper radiator. I can get an external cooler but I just don't wat to put a pipe in place of it I want to run a hose that way it will push out of the way some.
