Retarted question about TT
Old Aug 22, 2008 | 10:18 AM
Domexitium's Avatar
Default Retarted question about TT
I just want some clarification.
The purpose of a Twin turbo setup is so you don't have as long of a wait for the turbo's to spool, but you still have the capability of putting out as much power as a larger single turbo setup?
Old Aug 22, 2008 | 10:34 AM
1320's Avatar
Yes, but sometimes space and packaging is an issue, as well as cost.
Its probably easier to get two smaller turbos on a c5/c6 then one large single. Ofcourse for a c5 or c6 you use the most expensive turbo you can , cause otherwise it wouldnt be good, from the end users view.
Old Aug 22, 2008 | 10:39 AM
Zombie's Avatar
LOL, Troof!
Old Aug 22, 2008 | 10:41 AM
Domexitium's Avatar
DAMN 1320!!
You must effin love turbo's! look at your damn sig! **** man.
So, what type of system would you recommend for a stock 347, that will in about a year or so be going to a 402, or maybe a 408? Is that too dramatic of a difference in cubes so spooling and total power output will be hurt from that small of an engine to a larger one? In other words will a TT setup work on a 347and also work just as efficiently on a 408?
Old Aug 22, 2008 | 10:59 AM
hellbents10's Avatar
LS1Tech Sponsor
Single "S" unit from FI would get you going and be good with more cubes. I am thinking truck manifold setup.
Old Aug 22, 2008 | 11:06 AM
Domexitium's Avatar
Hellbent,
can I get a link to what you speak of?
Old Aug 22, 2008 | 11:07 AM
1320's Avatar
it depends on a lot of unanswered questions.
1. use of the car? street car, drag car, street/drag car, road car/autocross
2. ac?
3. BUDGET?
4. fabrication skills.
5. m6 or auto? If auto what kind? 4l60, 2004r?4l80, th400.....?
Old Aug 22, 2008 | 11:09 AM
1320's Avatar
This would be the direction I would lean also, without knowing more and guessing at the use and being resonable on the budget side.
Old Aug 22, 2008 | 11:18 AM
Domexitium's Avatar
2. ac?
3. BUDGET?
1. street/drag
2. deleted
3. just testing the water
4. none
5. currently an m6, but tossing around the idea of either a 4l80 or a built t-56
so, kp do you have a link to this s kit you guys are talking about?
Old Aug 22, 2008 | 12:40 PM
LS1Tech Sponsor
Not a kit, we do custom setups in house. KYTP makes a nice manifold kit if you want to tackle the rest your self though. The S unit would be right up your alley.
http://forcedinductions.com/productsborgwarner.htm
Now we just need to figure out how much power you want to make.
Old Aug 22, 2008 | 01:16 PM
98transguy's Avatar
so u are looking for something to put on stock cubes and keep the same turbo when u upgrade to a 402?i would probably go for something around 80mm maybe one step larger.Although i started with an s85 for my 383 and ended up getting upgraded to a s91!
Old Aug 22, 2008 | 01:48 PM
Domexitium's Avatar
I'm sorry guy's, I just suddenly realized I don't know **** about Turbo's. Is there anything that you guy's can recommend to read? any books or anything?
Old Aug 22, 2008 | 05:53 PM
ls1king000's Avatar
Read in this thread engineermike's posts.
https://ls1tech.com/forums/forced-induction/702786-i-have-theory.html
