What can 50#'s do???
Old Sep 3, 2003 | 09:59 AM
Noyzee's Avatar
8 second mod
Default What can 50#'s do???
I have 50# injectors. Just wondering what kind of power they can handle in a turbo application? Im thinking around 600rwhp. Close?
Old Sep 3, 2003 | 11:17 AM
Crunch's Avatar
Default Re: What can 50#'s do???
Thats what I'm using. They should handle 600RWHP with no problem.
Old Sep 3, 2003 | 11:55 AM
Noyzee's Avatar
8 second mod
Thats about what i was thinking. Im running them also. they show no sign of stopping. yet.
Old Sep 3, 2003 | 01:01 PM
BIGBOS's Avatar
Go with the Siemens 57 pounders, I've heard they are much easier to tune than the 50's, and thats the highest you can go w/out converting....
Old Sep 3, 2003 | 01:24 PM
Noyzee's Avatar
8 second mod
well, I already have the 50's in the car, Ive been running them for a while now. They seem to be ok. But I was hoping to keep these till I get my FAST system, then go to some big boys!!
Old Sep 3, 2003 | 01:26 PM
BIGBOS's Avatar
Yea I have a similar plan as well, my 42.5's are doing just fine with a CAS regulator and a hot wire kit....
But in the future it will be a FAST system and 83's most likely....
Old Sep 4, 2003 | 10:58 AM
ls1290's Avatar
Dumb Ass Vette Moderator
What about the Speed Inc impedance converter? How good is that? It looks way cheaper than going to a FAST setup.
Old Sep 4, 2003 | 11:17 AM
White_Hawk's Avatar
A guy in my car club (who posts here) made 600 rwhp with 42 lb bosch injectors with an intank walbro pump and a rising rate regulator from the 97 vette. The rising rate makes a big difference.
-Geoff
Old Sep 4, 2003 | 12:48 PM
BIGBOS's Avatar
The Speed Inc. converter is good for bigger injectors, but when you make enough HP you eventually have to step up to a different fuel management system, like FAST...
Old Sep 4, 2003 | 01:25 PM
smokinHawk's Avatar
a guy i know (the one with the yellow CE incon)
has 42lb'ers stock lines, rails, with a walbro 340 is running 10.11's, so hes got to be over 600rwhp.
Old Sep 4, 2003 | 03:35 PM
Phate's Avatar
smokin,
Is he using the intank pump that came with the Incon kit, or is he using a in-line pump as well?
Thanks
Old Oct 16, 2003 | 08:15 AM
ls1290's Avatar
How does the fast system work with the existing PCM as far as timing and other aspects?
Old Oct 16, 2003 | 03:09 PM
Currdog's Avatar
I'm running 55lb/hr injectors on the stock PCM and a custom fuel system (sumped tank, monster aeromotive pump, regulator, fuel-rails, feed/return lines etc).
I'll be installing the impedance box in the next few months to see what I can do on the stock PCM...
Old Oct 16, 2003 | 06:03 PM
BIGBOS's Avatar
The FAST controls the fuel, and LS1 edit is used to control the timing...
Old Oct 16, 2003 | 07:31 PM
ls1 joe's Avatar
Where do you get the siemens 57lb injectors
Old Oct 16, 2003 | 09:37 PM
BIGBOS's Avatar
Racetronix sells them
Old Oct 18, 2003 | 12:24 PM
smokinHawk's Avatar
smokin,
Thanks
he is using the reglator that came with it, i think he is using a walbor intank but not 100% sure, stock lines and rails too., but he says FP starts to drop off so that seems about the limit.
