Check out my custom fan setup.
Old Sep 3, 2003 | 03:14 PM
jrios's Avatar
Default Check out my custom fan setup.
Powerdyne cooling problems say goodbye
I’m running 1 16” fan and 2 8” fans. This will probably work for you ATI guys also. I’ve attached some pictures let me know what you think.
http://community.webshots.com/user/jrios126
Old Sep 3, 2003 | 05:19 PM
frcefed98's Avatar
Default Re: Check out my custom fan setup.
Lookin Good J. All that fits in there huh? I am still running the dual 12 inch FAL with built in shroud that I had bought for the PD kit. They are still mounted on the wrong side, but after I removed the A/C condensor, the car stays stays at or below 190 all the time even in traffic. Glad to see you are still messing with the PD. Any new track times?
Jeremy
Old Sep 3, 2003 | 05:37 PM
XFACTOR's Avatar
Sweet setup man-good idea-I bet that sucker cools everything down pretty quick!!
Old Sep 3, 2003 | 07:03 PM
jrios's Avatar
Jeremy
Thanks
I tried using the spal's as puller but it wasn't enough. No new track times. Probably later this year. But I got the belt slip issue taken care of since the last time I went to the track. I get 8psi everytime. Also, the internal belt seem to be holding in there.
Old Sep 8, 2003 | 07:17 PM
1dirtyZ's Avatar
any pics of them on the car? how much clearance between the head unit and the fans?
Old Sep 9, 2003 | 07:22 PM
jrios's Avatar
I'll take some pictures tonight or tomorrow with the fans install.
Old Sep 10, 2003 | 10:02 AM
1dirtyZ's Avatar
cool!
can't wait to see how it fits.
Old Sep 11, 2003 | 11:43 AM
jrios's Avatar
I added some pictures of the fans installed.
Old Sep 11, 2003 | 08:54 PM
1dirtyZ's Avatar
seems to fit really well!
did you have the radiator moved forward?
tell us how it work.
Old Sep 12, 2003 | 04:53 PM
jrios's Avatar
Yes, I did move the radiator forward.
The highest my temp has gone up with the A/C sitting in traffic is 200. I would say the temp had to be 98 degrees. The fans turn on high right at 185 degrees and I am running a 160 thermo.
Old Sep 12, 2003 | 11:28 PM
2002_TAWS6's Avatar
At what weather temperatures were you experiencing cooling problems?
Where did you get those fans from? Do they sound VERY LOUD?
And how much were they for?
