cogs....
Old Sep 6, 2008 | 10:12 PM
  #41
Jake@EPP's Avatar
Originally Posted by kp
You can have a crank support without a strut, just words
I would think that missing bolt on the iron block is going to hurt some.
Yep, maybe i can talk bob into a LSX block lol.
Old Sep 6, 2008 | 10:24 PM
  #42
frcefed98's Avatar
I have no reason to go with a cog setup really, F1C F1R maybe but this SDCE is working just fine for the F1A and down.
Same belt for over a year now, I dont replace them because I need to, I replace them because I feel guilty about leaving one on so long.
A properly set up cog works great though, I have never had one on a street car (except for a 8-71 blower) so I'm not sure how well they are suited for street use. At this point if I wanted an F2+ I would whip out the sawzall and hang a gear drive unit on the car - problem 100% solved.
Or just use a turbo
Somehow I think this is in the works for you...sooner or later
Thanks for chiming in Kev, always a wealth of knowledge and I like to use your car as the leading example on how great the SDCE set up works.
J
Old Sep 7, 2008 | 12:53 AM
  #43
kp's Avatar
kp
J
As much as like the procharger I just dont see a practical way to make what I consider more power with a decent $$/PITA ratio other than going turbo.
What I'm using is so simple and works so well its hard to switch though.
Old Sep 7, 2008 | 05:35 AM
  #44
EPP's Avatar
EPP
The LSX block is probably the way we'll end up going on the car, the extra head bolts would also be a nice addition. Maybe Brent can talk WJ out of one for us! Bob
Old Sep 7, 2008 | 12:00 PM
  #45
kp's Avatar
kp
You guys could always win the bracket race at the shootout and get one
Old Sep 7, 2008 | 01:20 PM
  #46
EPP's Avatar
EPP
Thumbs up
Lol, I think you'd have the best chance at winning the bracket race, Kevin! Your car seems deadly consistent, and you've run it enough you know exactly what it will do. You should go for it! Bob
Old Sep 7, 2008 | 01:26 PM
  #47
Jake@EPP's Avatar
Bracket racing
Old Sep 7, 2008 | 01:52 PM
  #48
kp's Avatar
kp
Bracket racing
Well OK, INDEX race lol - same thing
Old Sep 7, 2008 | 02:02 PM
  #49
kp's Avatar
kp
Na, I'll pass on the shootout this year. It was fun last year but not really what I'm into.
Old Sep 8, 2008 | 05:08 AM
  #50
EPP's Avatar
EPP
That's too bad, we were looking forward to seeing you there. Bob
Old Sep 8, 2008 | 10:12 AM
  #51
kp's Avatar
kp
I may ride up Sunday just to watch, have plans for saturday.
Old Sep 8, 2008 | 01:22 PM
  #52
Grr's Avatar
Grr
My new car runs a cog setup with a powergrip GT2 belt. It uses a YSi and the blower mount is very solid, and i have close to 2k miles on this belt so far and it shows no signs of wear yet. I think the biggest thing is adequate bypass. I plan on adding a second small BOV for high rpm decel just for extra insurance. Also i tried a couple different methods and ended up not running it very tight. i put a wrench on each side of the idler to tighted and simply push with a bit of body weight and tighten simultaneously, so i dont think there is much for side load on the crank.
Old Sep 8, 2008 | 03:41 PM
  #53
Jake@EPP's Avatar
Alot of company's tell you to use a deflection spec to tension the belt.
I believe gates has a PDF on the power grip for tension based on pulley size and rpm.
Old Sep 8, 2008 | 03:44 PM
  #54
stevieturbo's Avatar
What sort of speed are you spinning the blower, and what power ?
Old Sep 8, 2008 | 04:02 PM
  #55
TTPMatt's Avatar
We only have a very small sneak peek photo. We're starting to fabricate the standoffs and get the blower into location. We have the manual tensioner block on the lathe to make it out of steel.
Old Sep 8, 2008 | 04:32 PM
  #56
Jake@EPP's Avatar
Is that a snap-on or matco standoff lol.
We just ordered up a new belt to try out, pullies should be here tommrow. We are having standoffs machined asap.
Old Sep 8, 2008 | 06:03 PM
  #57
Rickys S/C Z28's Avatar
looks great i hope you guy and the guys at EPP get one of theses up and running soon
Old Sep 8, 2008 | 06:23 PM
  #58
Jake@EPP's Avatar
74,100 @ 6700rpm is just about right. The results before the belt broke look promising, only time will tell. So far were +4psi in the middle of the pull, lets see what this baby blower will do for us!
If that wont put us in the 8s, then slapping the gear drive and f3r from the GTO project better!! lol.
Old Sep 8, 2008 | 06:32 PM
  #59
Sorry Jake...I was directing that at Grr, with his YSi.
The Aussie guys wont tell me how hard they are spinning theirs ffs !!!!
Well, one did ages ago, and he told me 50k. So either he was deliberately lying, or else he got his internal gears mixed up ! But given how fast they run....I think its the former.
Old Sep 9, 2008 | 09:23 AM
  #60
TTPMatt's Avatar
Jake: Snap-On only sir. We are fabricating our standoffs now out of 4130N - 3/4" x .058".
