Any Superchargers W/boost controllers?
Old Sep 3, 2008 | 02:01 PM
sciff5's Avatar
Originally Posted by chriswtx
If you go with a 2 or 3 bar tune, the computer fuels on boost signal..So it only fuels for the boost it sees, weather 14psi or 20psi...as long as the tune is good..
SO the real question (seeing how you've done it before) what difference do you feel with your wastegate in place compared to a standard setup and are you having any problems with your setup?
Old Sep 3, 2008 | 04:39 PM
chriswtx's Avatar
No problems at all. Been on the car almost a year now. On low boost, it feels the same as high boost down low, then it just flat lines at 14psi but the car keeps pulling.. High boost and the waste gate never opens. Feels like its not even there..
Old Sep 3, 2008 | 05:13 PM
Rickys S/C Z28's Avatar
very cool
Old Sep 3, 2008 | 05:17 PM
Jake@EPP's Avatar
Id like to see some IAT data logs on low and high boost, in theory they should be about the same.
Id also like to figure a efficiency % on low vs high boost even though the impeller is at the same speed.
Someone needs to build a dang CVT transmission for these blowers lol.
Old Sep 3, 2008 | 05:23 PM
chriswtx's Avatar
I really don't care about efficiency on low boost or IAT's. Low boost is just for pissing around on the street. High boost is for racing...
Old Sep 3, 2008 | 08:23 PM
calongo_SS's Avatar
That is awesome, somebody was using their noodle to come up with that and actually try it.
Old Sep 3, 2008 | 08:28 PM
Black Sunshine/ 00SS's Avatar
interesting... subscribing..
Old Sep 5, 2008 | 01:43 AM
chuntington101's Avatar
now that would be good! PD blower style torque but with missive top end power. sounds good to me!
Chris.
Old Sep 5, 2008 | 02:43 AM
Avengeance's Avatar
I remember questioning this when I first started my D1SC install long ago....
After being squashed by all the folks here I never proceeded with it.... wish I would have. I alway had a feeling that a wastegate on a SC car would work.
Old Sep 9, 2008 | 09:52 AM
sciff5's Avatar
I've done this on my car..
I run an Greedy Profec B boost controller for waste gate control and a waste gate on my intake charge pipe with my supercharger with 2bar SD tune ..Waste gate is sprung for 6.5psi(on a turbo setup) but opens at 13psi on a supercharged setup. Pulled to 20psi(or so) for high boost, low boost bleeds air and keeps me at 14psi. Push of a button and I can switch from 14psi to 20psi...Makes 630rwhp on low boost and 720rwhp on high boost(17psi) at 5700rpm. Haven't ran it up to 6700rpm yet for the final dyno tune(new motor)...
So it sounds like a 6.5psi spring gives you 13psi.. Sounds like theres a 2:1 ratio there or close to it. So if I only want like 8 psi (when I'm on the stock shortblock) I'm pretty much SOL. I dont think they make 4lb springs.
Old Sep 9, 2008 | 11:12 AM
Aster's Avatar
I'd love to see what the dyno sheets look like for the power band on your low boost setting. That's got to be a pretty kick *** setup. Wonder why the 6.5lbs spring gives you 13 to 14 psi instead of opening at 6.5. Is it just a difference in where it is seeing the boost from?
That is pretty sweet that it works for you. Wonder what the difference in peek power would be if you pullied down to only run 14 psi of boost at max rpm vs using the waste gate to release the excess pressure.
Old Sep 9, 2008 | 01:36 PM
  #32
sciff5's Avatar
If you pullied it to 14psi at max rpm you'de lose power everywhere in the power band.. I would image it would feel like someone took your engine and lopped 2 cylinders off it.
Old Sep 9, 2008 | 01:57 PM
  #33
Aster's Avatar
I know you'd lose TONS of power under the curve, but the peak figure... I'm curious what the losses are up top from spinning the blower that much faster. If you're not losing much to turning the blower faster this would definitely be a great way of building the bottom end of the powerband while keeping the motor from blowing up at the top end.
Old Sep 9, 2008 | 04:34 PM
  #34
chriswtx's Avatar
I will have a final dyno of both boost settings very soon..Just waiting on a semi-cool day..
The reason for this is that on a turbo system at say 5psi of boost their is approx. double, 10psi of back pressure in the exhaust manifold. And that is used to help push open the waste gate...So thats the difference..exhaust pressure vs intake pressure..
Old Sep 9, 2008 | 05:09 PM
  #35
'Trust''s Avatar
1 question, how did you pull of a 2 Bar SD tune w/20 psi of boost?
Old Sep 9, 2008 | 05:24 PM
  #36
Jake@EPP's Avatar
It is done by PE once its out of range. Same concept when pegging the MAF. It goes to fuel x rpm.
Old Sep 9, 2008 | 05:43 PM
  #37
'Trust''s Avatar
Makes sense. Thanks
Old Sep 9, 2008 | 05:50 PM
  #38
chriswtx's Avatar
it actually reads to 2.5 bar (18psi) and fueling above that is done as stated above... .
Old Sep 9, 2008 | 07:08 PM
  #39
Inspector12's Avatar
TT-TECH Veteran
Yeah I had talked about putting one on a friends car and just didn't ever buy the parts to play with it etc... I never saw any articles, but I knew it could be done. Even the factory ATI bypass valve bleeds off presure as a mater of fact they never 100% seal that is why they aren't the greatest for big power cars etc...
Old Sep 10, 2008 | 07:53 PM
  #40
bboyferal's Avatar
I remember reading threads with this topic... TC's got freakin' flamed like they were asking about turbonators or something... And now look here.
The narrow-mindedness of some...
The devotion of others...
Guess who looks dumb now?
