Turbonetics T76 vs. TC76
Old Aug 18, 2011 | 12:43 AM
  #121
CarsandWomen's Avatar
Originally Posted by DrTurbo
I will check and see what I can find.
yes there is, its in one of your old threads. I think when yall first came out with it. its a pic looking down on teh inlets with the standard cover sitting on top of the GTM
Old Aug 18, 2011 | 08:21 AM
  #122
VUSS383's Avatar
How would these compare to the GTK-850 ??
I'm in the process of a 427 LSX build & have twin 850's going on it. Wanting to make well over the 1000hp mark . Whats your thoughts ??
Old Aug 18, 2011 | 09:50 AM
  #123
DrTurbo's Avatar
LS1TECH Sponsor
Yup...you are correct. I remember Jason taking that picture. I will see if I can dig it up.
Old Aug 18, 2011 | 09:58 AM
  #124
DrTurbo's Avatar
LS1TECH Sponsor
Wouldn't be close. The GTK's will not support near the power of the newer units.
Old Aug 20, 2011 | 07:16 AM
  #125
crashly's Avatar
twin gtk 850's = twin hp72's with out the surge slots ( and black comp cover coating)
twin 72's on 427 should make 1000+ easy
Old Aug 20, 2011 | 08:07 AM
  #126
VUSS383's Avatar
Thought I was on the rite track with my selection of the 850's . Just wasn't sure where they stood in regards to what has been mentioned in the thread.
The biggest problem I have with the Turbonetics is no flow data for my selected turbo's . I so hate choosing so blindly on such an expensive combo.
Old Aug 23, 2011 | 11:12 AM
  #127
DrTurbo's Avatar
LS1TECH Sponsor
All the manufactures are like that now. You won't find maps for Tnetics, PTE or most other companies that deal with aftermarket. Garrett, BW and Holset do have them though since they provide turbos for OEM's and they have to provide a CW/TW-map.
Old Aug 24, 2011 | 06:51 AM
  #128
VUSS383's Avatar
So is it possible to get hold of any maps for these ?? If not what do you guys use to know exactly what turbo's suit a given combo ??
Old Aug 24, 2011 | 09:20 AM
  #129
DrTurbo's Avatar
LS1TECH Sponsor
Their are maps available, but not for public use or viewing.
Old Aug 26, 2011 | 03:26 PM
  #130
DrTurbo's Avatar
LS1TECH Sponsor
Hoping to have a Billet HP GTM7676 soon for testing....will let you guys know how this is going to turn out.
Old Aug 26, 2011 | 03:41 PM
  #131
El_Diablo's Avatar
Please do..
Old Aug 27, 2011 | 05:27 AM
  #132
VUSS383's Avatar
Am I missing something ?? My GTK-850's have surge slots & black cover.
Also where I get lost with you guys talking turbo's is that you all seem to talk wheel size in the US , whereas over here we talk turbo specs such as GT 35/82 . So when you guys say 76 what would be the specs on this wheel ?
Old Aug 27, 2011 | 08:37 AM
  #133
52172's Avatar
yep 76 is the compressor wheel size. The TC76 now has a larger better turbine wheel to. All in the same small package.
Old Aug 29, 2011 | 04:06 AM
  #134
crashly's Avatar
gtk850 = T series comp cover, bullet drilled surge slots, black coated, hp72mm compressor wheel , BB, F1 -68 turbine wheel, with .81 a/r tang housing, T4
T72 = hp72 compressor wheel, t series comp cover polished, BB or journal, F1-68 turbine, any a/r housing that suits F1-68 turbine wheel , oncentre or Tang housing, T4
and the problem is ?
the only different is the bullet drilled surge slots basicly , which helps the turbo spool / recover on shifts or pedals
Old Aug 29, 2011 | 10:20 AM
  #135
52172's Avatar
Originally Posted by mike13
I wish they had that when I was running a TC76. I think the majority of users max the turbine side out before coming close to the turbo compressors potential.
I know tell me about it. However I have been very pleased with my TC76 with the little 68mm wheel. It does work fine for me on the street. It might choke a little bit up top with backpressure I think my valve springs can feel it. It runs like a raped ape though. If I ever take it off I will upgrade to the 76mm wheel and larger 1.15 housing since I currently have the .96 housing.
Old Sep 9, 2011 | 06:32 PM
  #136
BLINGOLE's Avatar
Man I'm so up in the air right now on turbos, I have a 370 tc78 setup now, but I want more! I'm between redoing my whole setup and getting a borg warner or a pt gts 76 or waiting for this turbonectics unit! Ugh I guess if I wait it'll be worth it but dam I hate waiting!!!
Old Sep 16, 2011 | 09:34 AM
  #137
BLINGOLE's Avatar
Any luck bud? Ive been checking this tread almost everyday.
Old Sep 22, 2011 | 10:15 AM
  #138
S13LSx's Avatar
DrTurbo..
I'm about to order a TC turbo from you for my 5.3L 240sx build.
Which turbo for a 5.3L, 243 heads, and a 216/221 .580 Lunati stealth cam in a 2700lb 240sx with a TH350??
TC72, TC76, or TC78???
What am I looking at for spool difference between the 3 turbos?
Thanks
Old Sep 22, 2011 | 01:01 PM
  #139
BLINGOLE's Avatar
Originally Posted by S13LSx
DrTurbo..
Thanks
My guess would be tc78, the tc76 is just about the same as the 78 but slightly smaller. I would go with a tc78 .96 and you would be good for a safe 650whp.
I may sell my tc78 if this new turbo was ready in the next two weeks.
Old Sep 22, 2011 | 01:23 PM
  #140
DrTurbo's Avatar
LS1TECH Sponsor
Trust me we are trying to get these things out asap. We will have a GP for them on release as well
