Turbo guys?
Old Sep 10, 2008 | 01:19 AM
tha joker's Avatar
Default Turbo guys?
what rear gears are you 10 second and less guys running and what size turbo?
Old Sep 10, 2008 | 09:05 AM
onfire's Avatar
Coal Mining Director
Ran 3.08 : 1 with twin 53's to 9.9 at 141mph.
Ran 3.08 : 1 with twin 60's to 9.2 at 146mph.
Old Sep 10, 2008 | 09:12 AM
MY99TAWS6's Avatar
If you search "boosted list" you can find lots of data on this subject. Seems many guys on there have run very fast with higher gears than most people think are best for turbos. Was quite suprised to find very many very fast cars running 3.73 and 4.10 although there were quite a few running lower gears as well.
Too low a gear nuerically makes a car very doggy off boost so then it depends on where and how quick your turbo spools up. I can't decide between 3.54 and 3.73 personally in planned dana 60.
Old Sep 10, 2008 | 09:32 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
3.50 gear, 28 tall tires, 9.4@144 with plenty of room I should be able to go 165mph.
Old Sep 10, 2008 | 05:34 PM
tha joker's Avatar
my stock gears are 3.46 and i was thinking of going with the 3.07 i have....good idea or no?
Old Sep 11, 2008 | 12:56 AM
engineermike's Avatar
Gearing has nothing to do with the type of forced induction or the ET. You gear a car to hit max rpm as you pass through the traps. It just so happens that turbo v-8's make a lot of power at a low rpm, and trap very high speeds. So, they need tall gears. I'm going 146 mph at 6200 rpm (my max rpm) using a 3.00 gear and 26" tire.
Old Sep 11, 2008 | 01:10 AM
MY99TAWS6's Avatar
Hmm most turbo guys say the load from the lower numerical gears helps the car make boost faster. Still really low numerical gears are pretty annoying off boost . I generally like around a 3.42 for around town snap in an auto and love 3.73 in the m6.
Old Sep 11, 2008 | 01:20 AM
Think about this for a sec. Exhaust energy (enthalpy) and mass flow are what spool up a turbo.
The energy is a function of temperature. EGT is the same at low rpm and high rpm, so the gear doesn't affect it.
Mass flow is a function of rpm and throttle angle. You get more mass flow at higher rpm. So, the sooner you can get an engine to a high rpm, the more mass flow you're going to supply to the turbo, the quicker it will spool up. I used to have a sloppy-loose torque converter in my car. The turbo spooled up really quick because the converter allowed the engine to reach 4000 rpm as soon as you hit it. Of course, with boost it would blow right through it, but that's a topic for another day. . .
Taller gears may SEEM like you get boost sooner, but it's only because you get it at an earlier rpm, not in less time. Heck, if you have a 6-spd and start out in 6th gear, you might get boost at 2000 rpm, but you're better off starting off in 1st and not getting boost until 4000 rpm. I assure you 4000 rpm in 1st will come sooner than 2000 in 6th.
Old Sep 11, 2008 | 07:11 AM
hellbents10's Avatar
LS1Tech Sponsor
Old Sep 11, 2008 | 08:34 AM
bluecamaroz28's Avatar
I think it's the lower rear gear (numerical higher number) that will load the turbo quicker but there is a limit if you don't want to run out of gear in the 1/4 mile or even on the street races.
It looks 3.5 and lower number is what most of the turbo guys are running.
Old Sep 11, 2008 | 08:38 AM
Black X's Avatar
I run a 3.73 and a 30" tire.. Was on a 28" tire but needed a little more to get it out the back door in the power.
Being rear mount my spool suffers a little but I noticed no difference in spool when changing froma 28" to 30" tire. Full boost of 13psi by 4000rpm in first gear.
Old Sep 11, 2008 | 06:46 PM
tha joker's Avatar
great info guys i really appreciate it.Im a turbo newb with a fairly badass setup,but since i just got it in i need alot of work to get to where im going.....
if it was'nt for this damn site and the fast guys i would still have my maggie and still be in the 10's.....Now im back at baby steps running 15 seconds my first run out,so sorry for the stupid questions but thats how im gonna learn.
Old Sep 11, 2008 | 07:00 PM
geeteego's Avatar
With all the help you've given out across the internet on LSxGTO, I think you get a bye on "stupid questions".
I'm hoping for a mid-10 slip at the Mustang/GTO meet on stock gears.
Old Sep 11, 2008 | 07:05 PM
ninetres's Avatar
3.25 gears here. TH400, 3k stall T4 ST80. 28"' ties on the track. ~26" tires on the street.
.....wait! You went 15 seconds on your first time out with a TH400 car? How?
Old Sep 11, 2008 | 08:27 PM
NA$TY-TA's Avatar
3.54 rear gears, S88 Turbo, Power Glide, 28" Radial track and street.
9.26@150
Same Gears, 30" Radial and a 106 up next
Old Sep 12, 2008 | 08:11 PM
tha joker's Avatar
yeah i did,my car has no power and im retarded,so i guess they balanced out to a 15...lol
I think there is alot of street tuning that needs to happen.We tuned the car on the dyno just to get it out on the track.This setup has 0 miles on the motor and only a few dyno pulls and i took it out....To say the least i was embarrassed
Old Sep 12, 2008 | 08:12 PM
tha joker's Avatar
thanks i try to help alot of people no matter what,and kick a mustangs *** for me while your at it...
