My build (truck/C6 manifold setup)
Thanks, I'm afraid the drain line wont drain right. I have the pan tapped on the front passengers side,the A/C compressor is right above it, the passengers side crossover is blocking it from the side and the front dosent look like it will work either. I knew it wouldnt be easy though.
Got a little more done yesterday.
Finished the drivers side of the crossover.
![](http://img382.imageshack.us/img382/3707/1001662dj0.jpg)
Tried to get as much clearance as I could for the 4" down pipe I plan to run so I had to make all these crazy bends.
![](http://img72.imageshack.us/img72/9669/1001658tb8.jpg)
Making a 45* fish mouth for the waste gate was fun.
![](http://img385.imageshack.us/img385/6439/1001659kj0.jpg)
For some reason I thought with this turbo I'd have more room, it fits OK but took up more room than I thought it should.
![](http://img56.imageshack.us/img56/7728/1001665oe9.jpg)
#35
hmmm do you have pics of the k member installed. i would like to see how much room. you will lose ground clearance going on teh driver side though. i did mine down the pass side but you are keeping AC. i made the 4 inch fit through there. i used a spohm k member with solid motor mounts. i used an older bmr one and gained no clearance over a stock k member.
keep up the good work i like some of the ideas you have. very well thought out
#36
From the back
![](http://img218.imageshack.us/img218/9317/1001387xz6.jpg)
From the front
![](http://img228.imageshack.us/img228/3971/1001388vd4.jpg)
#38
Sure I'll get a pic up tonight, I had plenty of room with the K-member. I dont mind posting pics up, I learned a lot by looking at others pics and started a little collection of pics of Turbos/hotsides,intercoolers/cold sides, down pipes, & oiling. Hope my pics can help others like others pics helped me.
