procharger gurus i braced my plenum, any adverse effects?
as you can see in the pics,
my plastic plenem buckled where the mass air hose attaches. no matter how tight i got the bellows i could just get rid of seeing light around the hose.
what i did whas take a small aluminum tube and crushed it almost flat(thin oval) and propped the plenum into shape. i then took a torch and heated the tube just enough to get the ends to sink into the plastic.
i cant pull it out with decent force and with the bellows and hose clamp on it should lock in even better. my maff is screened so im not really worried about it getting ingested.
my ? if will this have any real negative effects on air delivery? flow?
i plan on getting a metal or custom plenum but the snow is a month away and i just want to get some miles on this new motor before storage.
what do you think?
what do you think?
i will over the winter or if this pops on the dyno. i planned on eliminating the plenum all together with a y pipe but i changed work sites and lost tabs on a guy i was going to use for a fabricator.
