boost problems
Old Sep 14, 2008 | 01:17 PM
BoostBandit's Avatar
Default boost problems
Well, I put the my car on the dyno and I have an STS kit with a front mount. The wastegate has the 5 lb spring in it. just running off the wastegate the car made 4lbs. When I ran it through the STS boost controller ( which I have determined is a piece of crap) the car made 7 lbs, then on the next run it made 6 lbs and then went back to 4lbs. I wanted to put it up to 9 lbs but could not get a reliable boost setting. I was wanting to know if anyone has had this problem and if I get a 10lb spring and a boost controller that works if this will hopefully fix my problem.Also was wanted to know if anyone had a good diagram on how to route the boost controller on the STS kit just make sure I had it routed right. Thanks for the help.
Old Sep 14, 2008 | 01:33 PM
OHSIXCTSV's Avatar
watch what u wish for...10lbs on a stocker could get ugly. did u atleast upgrade your valve springs? turbo boost should be good for 20-25 hp per psi...200-250 extra rwhp
and kaboom! (in due time) on a stock bottom end. i'm not saying not to do it, just
be sure your bank account is up to the task.
Old Sep 14, 2008 | 01:43 PM
Well I want to go to 9lbs but I loose a pound through the intercooler. so that why I want a 10lb spring and a boost controller to adjust it to 9lbs.
Old Sep 14, 2008 | 01:50 PM
OHSIXCTSV's Avatar
they say 8 is the limit on stock bottom end...
i like to think more is better too...but, i would run it on 5-6psi
for a while to gauge what "normal" should feel like befor
you go extreeem. just my .02
how does the 5lbs feel? or you havent got out on the street yet?
Old Sep 14, 2008 | 02:23 PM
It has been on 5lbs for over a year now. And I live in colorado where the density altitude the other night on the dyno was 8,200 ft
Old Sep 14, 2008 | 06:44 PM
Silver_TransAm's Avatar
I have been running 10psi on stock 112k for a while now on the street and dog the hell out of it. Just get a good tune and you will be amazed. I just wish I had a trans that could hold it.
Old Sep 14, 2008 | 06:51 PM
OUTLAWZ RACING's Avatar
Do you loose boost on the street? Could be a load issue.
Old Sep 14, 2008 | 06:58 PM
CanII's Avatar
I have seen STS kits make almost no boost on a dyno jet because of the no load issue. If it doesnt have this problem on the street that is most likely your problem.
Old Sep 14, 2008 | 07:57 PM
OHSIXCTSV's Avatar
nothing like a mustang dyno with eddy current softwear.
the load simulation is as good as it gets.
Old Sep 14, 2008 | 10:23 PM
It is an eddy current dyno. The boost was just up and down because if you even bumped the boost controller it woul change the boost. But I ordered a light blue 8.7 lb spring and a good boost controller tonight. The guy I have tuning it is very good with HP tuners so the tune is the least of my worries its the 95K miles on the car that I am. But like silver said its all about a good tune.
Old Sep 14, 2008 | 11:14 PM
CanII's Avatar
You should try to pull off the boost controller all together. If the car ends up boosting what ever the W.G. spring is set at then you can eliminate your boost controller.
Old Sep 15, 2008 | 03:34 AM
HossinatorSS's Avatar
It could be the WG spring. I had my kit for about a year before the spring must have taken a permanent set and would only make 5.5 instead of 6.5psi. I thought it was because i had dented the crap out of the front pipe (STS does not like eibach pro-kits!) I bought a cheapo ebay manual boost controller and used it to adjust to 6.5 psi again. It worked. Still need to buy a new spring though. Like CanII said, remove the BC and just run straight spring. According to STS you should lose about .75psi through the piping alone plus what you lose through your intercooler.
