turbo size
Old Sep 15, 2008 | 08:41 AM
Chris'stransam's Avatar
Default turbo size
I am building a street and strip turbo 408 . The car is driven allmost every day, and the car is a m6. I am whant to run 10 - 15 psi .I need to know what size turbo to use .
Old Sep 15, 2008 | 10:40 AM
rubbersdown's Avatar
depends how much hp you want. If your looking for 850+rwhp go with an 88mm. If you are looking for crazy power, go with a 91-94mm. call forced inductions, they will hook you up.
Old Sep 15, 2008 | 10:49 AM
mohennessey's Avatar
91mm turbo would do just fine
Old Sep 15, 2008 | 11:00 AM
yah but with a good 91mm hes going to be making 1000rwhp at 15psi, in a daily driven m6 car he will be going through tires like there going out of style, the car will just sit there and spin all day long.
Old Sep 15, 2008 | 12:55 PM
DrTurbo's Avatar
LS1TECH Sponsor
If you have the funds, the S91 or the FI-91X would be the one to have. If your on a budget, then go with the GT88. 88mm unit for less then 1200 bucks. Hard to beat that.
Old Sep 15, 2008 | 01:13 PM
bluecamaroz28's Avatar
RWHP and ET goals can help in sizing your turbo. Also, which kit are you going with? Single or twin turbo?
I would say 80-91mm depending on your goals but being M6 will be difficult to spool 91mm on the street.
Old Sep 15, 2008 | 07:59 PM
Firechikn's Avatar
With the 91 at 15 psi, he should be close to 900 + or -. When I was running the 6 speed, my car would hardly spin at all. I could break spool in 1st to 11-12 lb and it would hardly roll the tires over. The only problem is him driving on 325/15 mt every day. No fun in the rain. haha
For the record. The 91 is not hard to spool with a 6 speed on the street. I could roll on it in 1st, full boost ( 14 lb at the time ), or brake spool rolling in 1st would get to 11-12lb real easy. Like stated above, the boost curve was real easy to hook. Prabably started spooling at 3200 full spool around 38-3900. The 6speed was much easier on tires than the new auto is, by a long shot. Reminder, I do run 325 mt dr's. I'm sure any street tire will be a smoke show.
Old Sep 16, 2008 | 08:21 AM
Default turbo size
Realy think I am gona use a GT88 turbo, unless some one can change my mind.
Old Sep 16, 2008 | 10:17 AM
DrTurbo's Avatar
LS1TECH Sponsor
For the price, you can't beat it.
Old Sep 16, 2008 | 10:33 AM
52172's Avatar
Is that a t-6 framed turbo?
Old Sep 16, 2008 | 10:34 AM
DrTurbo's Avatar
LS1TECH Sponsor
Yup...
Old Sep 17, 2008 | 07:11 AM
ok!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Sep 20, 2008 | 07:22 PM
pozesd99''s Avatar
if you have the funds try a y2k 88mm....
