Alternator Relocation Bracket That works?
Old Sep 23, 2008 | 06:55 PM
Monello's Avatar
Here are some pics of the setup.
Had the designer of the bracket himself drop off the parts. Great guy!
Only thing holding me back from starting the car up is the wiring. The new alternator plug has 3 wires that go into it. Our stock LS1 setup has 1 wire plug.
Any ideas guy? Anyone with a speed inc bracket in here that can help =).
Also what size belt are you guys using? All my pulleys are stock, and the idler pulley under the powersteering pump remains.
Old Sep 23, 2008 | 07:13 PM
FANTAZ28's Avatar
Moderator
yea you only use one wire.... i have to look at mine.
email larry and have him ask dan... he'll know exactly which one.
p.s. i think you have to swap in the pully off your stock alternator also.
Old Sep 23, 2008 | 07:21 PM
Monello's Avatar
Yea Kevin told me to swap it out.
Can you take a quick look at yours a post a pic? pleaseeeeeeeee =)
Old Sep 23, 2008 | 07:23 PM
black98ws6ta's Avatar
Originally Posted by fenix999
PM sent monello. PM sent WestSide.
Backdoor sales?
Old Sep 23, 2008 | 07:25 PM
Monello's Avatar
lol no, fenix was giving me some advice on the bracket. Nothin more.
Old Sep 23, 2008 | 08:42 PM
LS1 SPEED's Avatar
I will get back to you tomorrow on the correct wire.
thanks for your patience
Old Sep 23, 2008 | 10:28 PM
Tiago's Avatar
does this setup still use a tensioner?
Old Sep 23, 2008 | 10:34 PM
LS1 SPEED's Avatar
alt. becomes a manual tensioner
Old Sep 23, 2008 | 10:41 PM
fenix999's Avatar
Originally Posted by black98ws6ta
Backdoor sales?
just trying to help out, wish somebody would have helped me when i was in the same spot but it was wayy back before i had the knowledge i have now. Ive seen and had way to many similar problems with this alternator relocation stuff and i know it can get frustrating and paralyze your entire build in the mean time, i just have very important and useful info on how to solve the relocation problem without breaking the bank, thats all I also want to add that the Speed inc setup pictured looks very nice, that bracket looks tough! good stuff guys keep em coming
Old Sep 23, 2008 | 11:09 PM
FANTAZ28's Avatar
Moderator
you can... but the bracket is slotted to tension using the alternator it self.
i removed my manual tensioner and used the bracket. works like a charm! ive had nothing but belt issues till i bought this bracket.
Old Sep 23, 2008 | 11:11 PM
Monello's Avatar
Yea im betting that you could stand on this and it wouldnt bend =)
lol
Will post updated pics tomorrow of the wire hookup.
Old Sep 24, 2008 | 11:19 PM
  #32
67Firebird455's Avatar
Glad I came across this thread, was just stressing about a good working unit for the 67! Twin 70 trims up front, don't need some oakie pinokie stuff going on.
Old Sep 25, 2008 | 10:45 AM
  #33
Monello's Avatar
Update!
Drove the car to work today, which is about a 30min drive and the belt stayed on!!
Will post pics later tonight. The alternator sits so low compared to the old setup. It almost looks stock!
The great thing about this setup is changing belts out is now very easy. All that is required is hex key.
Wanted to say thanks again to Larry from Speed Inc, and Kevin from Machinehead for making a quality bracket.
Old Sep 25, 2008 | 11:56 AM
  #34
Frost's Avatar
looks like it will clear aftermarket fuel rails and fittings pretty well too.
Old Sep 25, 2008 | 12:08 PM
  #35
Monello's Avatar
It should clear with a lot of room to spare. This bracket bolts where the tensioner used to be, while the other kits bolt into the head. So we are saving like 3-4 inch, which means that it is a lot farther away from the hood.
Old Sep 25, 2008 | 06:27 PM
  #36
Monello's Avatar
Drove home from work and the belt is still perfect!
This is the FIRST TIME EVER, that I have driven somewhere and back without shredding a belt!
This is a true bolt on alternator relocation bracket. There was NOTHING to shim, it is aligned perfectly when you bolt it on.
Belt size is 74inches if you use the stock pulley underneath the powersteering.
Also you need to use the wire marked as L on the new connector.
My Review is A+ for design, quality, and simple installation.
Sits VERY low, so no problems with an aftermarket fuel rail!
Old Sep 25, 2008 | 06:47 PM
  #37
Pat-Man's Avatar
Looks great! Just wish it wasn't so expensive! I'm a poor boy.
Old Sep 25, 2008 | 08:36 PM
  #38
LS1 SPEED's Avatar
Pat...thanks for the nice detailed post.
Pat-Man did you not see the new pricing which includes everything?
Old Oct 2, 2008 | 04:13 PM
  #39
Pat-Man's Avatar
I have not seen that. Is it on your web page?
Old Nov 5, 2010 | 02:24 PM
  #40
Here's more pics of the SmokinHawk relocation bracket I got installed last night. Did have fenix99's setup but had to put the tensioner on the DS head so I lost my power steering.
Attached Thumbnails Alternator Relocation Bracket That works?-img_0998.jpg   Alternator Relocation Bracket That works?-img_0999.jpg   Alternator Relocation Bracket That works?-img_1001.jpg   Alternator Relocation Bracket That works?-img_1002.jpg
