Alternator Relocation Bracket That works?
Old Nov 5, 2010 | 10:24 PM
  #41
armintheman's Avatar
so smokinhawks design has a flaw or has he fixed it?
Old Nov 6, 2010 | 06:00 PM
  #42
MUSTANGBRKR02's Avatar
Use the speed Inc set up! Pricey but no thrown belts or slippage.
Old Nov 7, 2010 | 07:06 PM
  #43
67Firebird455's Avatar
I have yet to run it. Looks great so far. Seems pretty sturdy, not sure at 7,000 RPM but will report back in spring when I get this thing fired! lol I have an underdrive pulley so picking up a 71.5" and 72.5" belt and see what we're working with.
Old Nov 8, 2010 | 07:14 AM
  #44
smokinHawk's Avatar
ive ran mine up to 7200 rpm's with out a problem.
Old Nov 8, 2010 | 03:02 PM
  #45
71.5, 72.5 and 73.5 didn't work. Picking up a 72.1 right now, should do the trick. Will report back.
PS - Remember, I'm running an underdrive.
Old Nov 9, 2010 | 06:26 PM
  #46
The Gates K060722 (6PK1834) ended up working with my underdrive. 13/16" x 72 3/4" Outer Circumference.
Old Nov 30, 2010 | 05:20 PM
  #47
Pat-Man's Avatar
That looks like the one that fenix999 (member on here) used to make (I think he made them). Not sure if he still does. Ordered one from him back in '09, but I could not use it since I have an LQ9 block. It doesn't have the lower accessory bolt hole to move the tensioner to.
Old Dec 9, 2010 | 07:01 PM
  #48
It is... if you don't use power steering, you can actually put that bracket (that usually goes down low) on the drivers side head flipped and it works fine. That's what I originally planned to do but wanted PS so got the other unit.
Old Dec 10, 2010 | 11:43 AM
  #49
nahasapeemapetalon's Avatar
FWIW. Speed INC bracket and altnerator. The belt misaligns and shreds if tightened too much. I found a happy medium with ocassional belt squeal at startup,and the belt is fine.
One of the better looking units IMO.
Alternator used in this kit is 105 amp i believe and i bought a spare one for the power tour at a local parts store, when it gets hot it quits charging well. I just need to get underhood temps cooled down.
Old Dec 18, 2010 | 09:39 PM
  #50
blackmagicturbo's Avatar
Heres some pics of mine ,let me know what you guys think ..
Attached Thumbnails Alternator Relocation Bracket That works?-altbracketls1camaro1.jpg   Alternator Relocation Bracket That works?-altbracketls1camaro2.jpg   Alternator Relocation Bracket That works?-altbracketls1camaro3.jpg
