oil drain scavenge pumps
PSJ,
Bummer on the motor.. not sure if you are still interested but this pump is the ****!
Chris
Terbowerx Full Boogie Scavenge pump
Chris
![](http://www.turbowerx.com/Scavenge_Pump/Exa-Pump/files/page23_1.jpg)
LS1Tech Co-Founder
Haider the motor wasn't that smoky before, but it became smoky as of late.
Okay so what I learned from my calls:
...Oil pressure for turbo feeds can be restricted, but you would need to ask around and see what's reasonable. Found that keeping it above 10 psi is reccomended. Restricting at the engine is reccomended.
...-12 oil drain is reccomended.
...If your turbo has pushed oil past the seals, you don't have to right away send it off to inspection and repair. If you can fix the pressure/draining issue try that first.
...It was suggested that I clean out the intercooler as there might be oil in there.
...Folks reccomend that the oil drain line be vertical coming out of the turbo.
talk to Schantin up here, he knows about the scavenge pumps and such. There is actually a scavenge pump that porsche uses and Schantin posted it somewhere. The one posted here is also a good pump
LS1Tech Co-Founder
Okay looks like I might be able to get a shortblock done before Memphis, I'll know by end of day tomorrow if it can all come together, but it looks very promising. Weber Racing is potentially willing to burn some midnite oil to get a particular combo out to me.
#32
LS1Tech Co-Founder
i can get a 4 bolt done in a couple days and i honestly am preferring an ERL type block for a 6 bolt setup but I don't think I can get one of those blocks turned around and built fast enuff... I heard that some folks have charged as much as $1800 to machine an LSX block eesh.
#34
7 Second Club
#37
LS1Tech Co-Founder
I didn't know much about how it cost to machine a block for a 7 or 8 second car, after talking to a few folks I see that $1500 would be dirt cheap for a 7 second car, some folks spend $5-6K.
Looks like an ERL would be 110 lbs lighter than an LSX.
My buddy is going to go leak down a few more cylinders based on some advice from Kurt Urban, and we'll see if this block is completely toast.
Way to kick a guy when he's down Brian, I look forward to picking up your scrawny balding *** and throwing it in a dumpester in Memphis. (ie **** you bitch).
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#38
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Way to kick a guy when he's down Brian, I look forward to picking up your scrawny balding *** and throwing it in a dumpester in Memphis. (ie **** you bitch).![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
wasn't kicking anyone...theres a BIG difference in what you or I are doing vs. what the big boys are trying to do power wise...hey...the most my turbo made on the dyno was 500 rwhp
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
#39
LS1Tech Co-Founder
My friend dicked around with the car today, but the block needs to come out is the final verdict got some help from Kurt Urban on some things to check.
Looking into ERL and LSX block setups.
