ATI Twin ICs - Move to front side by side?
Old Sep 21, 2008 | 10:12 PM
N4cer's Avatar
Default ATI Twin ICs - Move to front side by side?
Just following up on a discussion I had today. With the ATI Procharger twin IC kit (for a C5), could they be placed up front under the bumper to increase efficiency? I think they'd have to remain independent instead of all the flow going through both of them consecutively. But could it be done?
Old Sep 22, 2008 | 04:58 AM
EPP's Avatar
EPP
I'm confused as to what you are asking? Bob
Old Sep 22, 2008 | 06:50 AM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
You and me.
Old Sep 22, 2008 | 08:28 AM
AFASTYZFR1's Avatar
something like this..?
Old Sep 22, 2008 | 11:51 AM
N4cer's Avatar
Exactly. I never hear of people doing that. Is it acceptable?
Old Sep 22, 2008 | 12:03 PM
I would just go fmic at that point.
Old Sep 22, 2008 | 12:05 PM
JAILBAIT's Avatar
Major heat soak in one intercooler. Not suggested, get a single fmic
Old Sep 22, 2008 | 12:25 PM
'Trust''s Avatar
No wonder these IC's are insufficient, they are tiny.
Old Sep 22, 2008 | 12:59 PM
N4cer's Avatar
Yes, but I'm talking about making do with what comes with the kit before going single FMIC. Sorry I wasn't clear enough. Changing to FMIC wasn't in the question.
Old Sep 22, 2008 | 06:14 PM
DeltaT's Avatar
You never want to run twin IC's in serial (one after the other) because you end up with less heat rejection (the 2nd one doesn't do much work) and double the restriction. Move them if you want, but make sure they are fed in parallel.
Jim
Old Sep 22, 2008 | 07:21 PM
EPP's Avatar
EPP
We got them to work quite well in this Corvette.
http://www.exoticperformanceplus.com...Car.php?car=54 Bob
Old Sep 23, 2008 | 01:31 PM
03blackZ06's Avatar
Mine work well 644rwhp 03 z06 cam and d1sc
Old Sep 23, 2008 | 02:41 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
If anything I'd flip one so the inlet is on the top right and weld the two together. Inlet = top right and outlet = bottom left. That would be a lot cheaper than buying a FMIC core and work better than what is pictured. That's if you can weld aluminum or know someone who will really cheaply.
