First race with my Nova-62
6.0 lit
Stock crank
Stock heads with 2.05/1.6" valves
TSP Giant cam with 115 lobe
S480 turbo
E85
15 psi boost
And i ran 8.53@160 mph with 1.27 60-feet.
Here is the vid: http://www.youtube.com/watch?v=eLQwlaKwNxo
It´s the blue nova.
Looking forward to some 7 sec runs next year
The problem was the converter, no more trapspeed even if i boosted 20 psi.
I´m going to dyno it in a engine dyna and order a custom converter for next year. I think i´m going to upgrade to a 4" crank also..
Ecu is a Vipec V88. www.vi-pec.com
How high is compression ratio?
Which injectors?
Which pistons and rods?
How much your heads flow? I assume they are ported 317s?
What's your trans?
Great work again !!!
Wiseco pistons with tool pin upgrade
Eagle rods with L19 upgrade
160lb injectors
I don´t know flow. They are only very mild ported.
TH400 tranny.
90% injector flow at 20 psi.
So it´s well over 1000hp, but my converter didn´t like it
