Turbo LS1 Update (pics)
the engine was stock just 9:1 forged pistons... i busted that one up good
anyways why would you need a T78, are you able to push the T76 to its limit.
i still dont believe that the log cant support the T76, it powered Raymers car with the 2.5"DP to 9's at 707rwhp. ANd in an early thread we talked how the turbo tech wastegate would bypass the log to allow more HP. Basically the turbo just needs enough velocity to spin the turbo to X amount of boost, then the rest should flow out the wastegate. SO the real key is to devolop an effient wastegate system.
The turbo is a true T76 compressor. im not sure the exhaust side but i think it is an .96 AR housing. you can mix and match the compressors to exhaust side of a turbo. Ive heard talk of switching to a .89 ar housing for better spool time, but no one seems to car about that now cause wed rater have more top end HP.
So, you made 424RWHP with stock heads and cam @ 7PSI. Just forged pistons and lower compression with the T60. I hope maybe my CNC heads and cam will give me at least 50RWHP. I'll keep you guys updated.
And smokin I'm interested in the DP. I can send it to you paypal. Shoot me an email : mekkadon@comcast.net
fwiw the kit is sold and the new turbo system going on the car will also be using my crappy tuning.. hey btw did you hear that rob himself now is running the same amount of timing that is in my crappy tune... WEIRD!the larger turbo's have a less agressive turbine wheel that keeps exhaust pressure down.. the lower the exhaust pressure pre-turbo the more hp you can make... unfortunately at a point you have to oversize the turbine blade so much that the turbo just doesnt spool correctly.. familiar?? the opposite is true of the smaller turbos on the same exhaust configuration.. you get great spool because of the really agressive impeller, but then you will get boost stall, and then boost drop because there just isn't enough room to get the exhaust around the turbo.. that being said turbine sizing is critical on a log style set-up.. instead of just optimizing you can fly or dive just a little to either side of perfect.
thats what i think anyway.
Is it hoping to get fast by osmosis?!
Good Luck
Gary
dude, your car I gonna be nice when you get it back man! Whatup?!
