Does Boost Change??
Old Sep 9, 2003 | 05:41 PM
NA$TY-TA's Avatar
Default Does Boost Change??
Does boost change from the street to the dyno?? I had the 4" pulley on my car and i dynoed the car with it and only saw 4 pounds of boost. I asked you guys wich pulley to go with to see 8-9 lbs and the 3.2 pulley is what i was told. BlackLS1 T/A mentioned to go with a 36" pulley the closest i could find to that was 36 1/8 by gates. ATI said to go with a 36 1/2. I am only seeing about 6lbs and theres no dust on the pulleys so i dont think im slipping. Its only been on there for a week. How much does traction have to do with it? Shouldnt i be seeing closer to 9lbs?? I only have LT's and a small cam. Thanks for your input.
Old Sep 9, 2003 | 08:27 PM
Black LS1 T/A's Avatar
Moderator
Default Re: Does Boost Change??
How high are you rev'ing?
What is your elevation above sea level?
What do you see immediately... does it make about 4 initially and and peak at 6?
What size tires and gear are you running?
At the end of the day, the best people can do is give you a guestimate... that is why we keep saying NO ONE can tell you exactly how much boost a pulley combination is going to get you. I've got five pullies to attest to that.
Old Sep 9, 2003 | 08:37 PM
RyanJ's Avatar
SSU Moderator
supercharger boost I asssssume would not change. Boost from a turbo does as does your A/F as they are dependent on load and the dynojet does not give accurate load...a mustang dyno does.
Old Sep 9, 2003 | 09:33 PM
NA$TY-TA's Avatar
BlackLS1 T/A Im rev'ing to 6300.
Im right at sea level right on the coast.
It gradually rises to 6.
Im running 295/35/18s for the street and 245/50/16's Nitto 555r's for the track but i havent put them on since the new pulley. So what size pulley should i go with now?? HA HA I can already see a pile of pulleys adding up. Thanks
