Who has a F3 procharger with gear drive on a 4th gen?
I know Brady is doing it on his BBC with a F3R, Is there anyone here doing it with a LSx in a 4th gen? Do you have Pics I could see of your setup? I have some crazy ideas but want to see what mods need to be done to get there.
Thanks,
Dan
Thanks,
Dan
I almost started a geardrive/LSX project because it looks very good for high power without broken belts, and also is better for the blower because of the lack of side load on the input. NMCA rules don't allow it in EX/S, or it would have happened.
Kurt
Kurt
Hi Kurt, good to hear from you. Is it the gear drive thats not allowed, or the F3? BTW, is your email and phone numbers still the same? I may need to call you soon.
Dan
Dan
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Anything will fit with a long enough saw blade or plasma cutter. Not much room for a radiator. The f3 is a BIG unit for sure, with a gear drive and custom balancer it will kick it out a good 7-8in + whatever the blower is. So you will be close to the bumper so you can run a peice of pipe out the nose.
It is HEAVY and is out far on the nose, if your running a motor plate then you can brace it to the body as well.
Good deal. Looks like the the upper and lower brace will need to modified plus the use of one or two small radiators. I like the idea of the inlet going straight out the front bumper too. No alcohol for me, but that would be one way to go. Yes, a motor plate will be a must. If, this works out, I'll have to see if I can get rid of my new un-used complete OFI kit and S91. If I keep it, I will change it up a little still.
Its the gear drive and the F3. We submited a F1R with gear drive and they said no, belts only. Working on the engine with belt now, but hoping for a rule change this winter!
My cell phone is still the same and also my AOL e-mail kuperf@aol.com
Kurt
Kurt
Kurt
Kurt
