new Project F1C
Old Oct 1, 2008 | 03:15 AM
vette_c6's Avatar
Default new Project F1C
guys my new Project is F1c 15 PSI pulley
Stroker 403
Fast intake 92
Direct Port Nitrous Zex ( wet )
what is the best Camshaft you recommend guys ?
what RWHP i can get ?
what should AFR when i use Nitrous over F1C ?
about the Fuel injector
i bought 79 hi fuel injector ,, will they be fine ?
and i also heared that Corvette c6 doesnt need to change the Fuel System .,, Just Fuel Pump + hot wires + boost a pump + injector
is it true ? or i should change the Rar fuel ?
hope i get answers
i wish a companies replay me and tell me what kind of Camshaft ? and i dont mind buying a camshaft and after i finish my stuff i Post the dyno sheet for that Company
i hope i get the answers
cheers
Old Oct 1, 2008 | 04:31 AM
venom ws7's Avatar
Check EPP Blower camshaft work awesome with F1C and great idel or get custom grind.
Why nitrous?? with 15psi F1C and 403ci the car should be over 800rwhp.
I think 79 Injectors will be fine (without the nitrous) and I also think your right About the fuel rails you dont need to change them.
good luck and hello from Saudi Arabia.
EPP's Avatar
EPP
Our blower camshaft works very well for a lot of combinations. We used it in the C5 that we built a 402 for, and we also installed an F-1C. http://www.exoticperformanceplus.com...Car.php?car=40
For anything over 10 psi or so, you are going to need a completely new fuel system. Bob
Old Oct 1, 2008 | 08:37 AM
Street Legal's Avatar
why nirtous with F1C ? just choose either blower or nitrous setup
79# inj are enough ,even 60# with great fuel system will support up to 820RWHP with 115 120 duty cycle so 79 will be fine
good luck
Old Oct 1, 2008 | 08:57 AM
ls1290's Avatar
Dumb Ass Vette Moderator
There is no way in hell 60# injectors will support 820 rwhp. My old 75# injectors where starting to max out at 90% duty cycle around 4200 RPMs making a little under 800 rwhp.
Old Oct 1, 2008 | 09:18 AM
yes it will am arunning 408 d1sc car made 750 with 60s#@ 85% duty it dependes on your fuel system and your fuel pressure
Dont try to be an expert on my a**
Old Oct 1, 2008 | 09:22 AM
EPP has a c5 with an f1c that makes 804 with 60s and 120 duty
Old Oct 1, 2008 | 09:25 AM
ls1290's Avatar
I did not say that it can not be done. I said that they will not support it. IMO pushing injectors over 100% duty cycle is not good idea and is only asking for trouble down the road.
Old Oct 1, 2008 | 09:35 AM
nvmy2000ss's Avatar
Possible yes but I wouldnt exactly call it safe. Idealy around 80% duty cycle is safe. I wouldnt take the chance on leaning on a motor that is that expensive, its just not worth it. You could up the pressure but I still dont know if that would do it (60's). Good luck on the build.
Old Oct 1, 2008 | 09:36 AM
you wont have any trouble because you aren't driving the car for hours under WOT LOL
it's just a rule of thumb to get the duty cycle to 80% i dont think 100% will kil them
stock factory cars reach 85% 90% duty with no problems
the point is if he wants 79# it will be more than enough if you keep your fuel pressue up
Old Oct 2, 2008 | 10:52 PM
vette_c6's Avatar
well guys
thanks for the help
i got boost a pump
Aromotive Fuel pump with hot wire
also the fuel injector will be 79
is that enough ?
i heared that C6 Z51 fuel Rail wont be need to change ?
what about the Fuel lines ?
do i really have to change them ?
or i can go with it enough ?
thanks for the Camshaft ,, i will look at it and i will make an order for it
also another question guys
i have East Coast magnacharger adjustable tensaior
can i keep using it ? just fit the 8 Rib pulley ?
or i have to remove it ?
Old Oct 3, 2008 | 05:06 AM
EPP's Avatar
EPP
Exclamation
No we don't have 60 lb injectors in there. When we swapped from the 346/D-1SC to the 402/F-1C we swapped the injectors for larger ones. I would not run 60's at that horsepower level, too easy for problems to crop up. Bob
Old Oct 3, 2008 | 05:14 AM
EPP's Avatar
EPP
Thumbs up
Originally Posted by vette_c6
well guys
thanks for the help
i got boost a pump
is that enough ?
Take a look at these fuel systems.
http://www.nastyperformance.com/Corv...elSystems.html Bob
Old Oct 3, 2008 | 07:21 AM
well Bob if you have a fuel system that will keep your pressure high up top. 60s# will be enough, why dont u ask one of your techs lol this is what you always do when some one calls.
if your 79s# are rated @58 and your pressure drops up top what gonna happen ? do your math Bob LoL
it seems you know a lot when you guys installed ECS fuel system above the tank ,now i see why 60# wont be enough
Old Oct 3, 2008 | 07:27 AM
well guys
thanks for the help
i got boost a pump
is that enough ?
Dude dont waste your time in buying stuff u dont need, keep your stock fuel rails and install a fuel pump inline with the stock pump, then activate the pump with a boost swtich, all you need is a fuel pump that supports your goal/boost refrence fuel pressure regulator/and fuel line from the tank to the pump ,pump to fuel rails , and from the fuel regulator back to the tank
Old Oct 3, 2008 | 07:16 PM
UNIQUEC5's Avatar
What is your final goal with your set up?? It looks like you are going to be building 1 hell of a beast!!
Old Oct 4, 2008 | 10:07 AM
Jimmy P's Avatar
I agree. If you want more power, just put a smaller blower pulley on it. My F1C setup is seeing 18+ lbs of boost on a 402.
Old Oct 4, 2008 | 10:18 AM
EPP's Avatar
EPP
Exclamation
We get tons of calls all day long, many are not to buy parts, many just want help with something they have a problem with. If I don't know the answer then I see if one of my techs can help. I don't know everything but I do my best to help people out.
Where in the world did you get the info that we were running that F-1C with 60 pound injectors at 120% duty cycle??? We swapped to larger injectors before we even fired it up.
We initially installed the ECS fuel system per their instructions, then when we had fuel vapor problems after being on the road for over an hour, we lowered the pump to prevent the vapor lock. This pump is still supplied from the stock pump anyway, so it doesn't matter anyway. Bob
Old Oct 6, 2008 | 11:01 AM
vette_c6's Avatar
thanks for the answers guys
i will go for external Pump wilbro 255
injector 79#
and Fuel lines
and i will see what will happen
Old Oct 6, 2008 | 12:58 PM
sciff5's Avatar
injector 79#
and Fuel lines
A walbro 255 is not enough. You will need at least 2 but more likely 3 walbro 255s to be safe. Bosh I believe makes a very reliable pump thats similar to the walbro 255s but supports more power and is relativly cheap. You could get 2 of those and be fine or get 1 aeromotive A1000 fuel pump. That should be enough.
Your fine in terms of your injectors. If you want to go with nitrous as well.. you'll need an even bigger fuel pump. So keep that in mind.
