procharged 2002 ss on corn
Old Oct 1, 2008 | 03:09 PM
tsneath's Avatar
Default procharged 2002 ss on corn
Dropped my car off while back to get tuned for e85 with the procharger. 11lbs of boost car made 581hp and 596tq.That was on a dynamics dyno also. I'm running out of fuel at 5800rpm I guess I will have to get some bigger injectors. Car is an 2002 35le
long tube header
off road y
factory slp center mount
moser 12 bolt 3.73 gears
spec 3 clutch
lunati 221/224 cam
forged rods and pistons stock crank
60lb injectors twin pumps dual fuel line aeromotive rails boost refernce regulator
stock ported and polished heads
I'm really happy with the numbers especially tq. I will post dyno graphs when I pick the car up next week.
Old Oct 1, 2008 | 03:17 PM
Street Legal's Avatar
what is your fuel pressure at WOT ? with dual pumps and 60# u should be fine over 700RWHP
Old Oct 1, 2008 | 03:20 PM
tsneath's Avatar
I didn't get very long to talk to the tuner. You think it should handle that with the e85. The research I was reading guys have been saying it takes anywhere from 30 to 40% more fuel at wot on e85.
Old Oct 1, 2008 | 03:24 PM
hellbents10's Avatar
LS1Tech Sponsor
That would be about max on e85.
Old Oct 1, 2008 | 03:36 PM
ICRAZY6's Avatar
Needing 90lb's or larger.
Old Oct 1, 2008 | 03:37 PM
my bad i haven't seen the E85 lol
ture just about max with E85
Old Oct 1, 2008 | 03:56 PM
allthrotle's Avatar
Are you running the stock size fuel lines?
Old Oct 1, 2008 | 04:42 PM
tsneath's Avatar
No all the fuel lines and fuel rails have been upgraded.
Old Oct 2, 2008 | 04:43 AM
EPP's Avatar
EPP
Here is what I would use. Bob
http://www.exoticperformanceplus.com...html?item=1079
http://www.exoticperformanceplus.com...html?item=1103
Old Oct 2, 2008 | 07:00 AM
No Juice's Avatar
Is this a speed density tune or are you still running the mass air meter?
Old Oct 2, 2008 | 08:07 AM
SPRAYED 01's Avatar
Hey Bob,
Does that driver come with a wiring harness??
Old Oct 2, 2008 | 08:09 AM
slow67's Avatar
Gingervitis Addict
Racetronix makes a wiring harness for it
Old Oct 2, 2008 | 08:26 AM
tsneath's Avatar
He did a custom operating system in it. So it should be speed density.
