Another ebay build
Old Oct 12, 2008 | 09:08 AM
  #41
Hennytime's Avatar
Originally Posted by Chhh Chhh
very nice job paintin
very nice,
how hard was it to drop get the oil pan out, what all did you do?
Old Oct 12, 2008 | 09:51 AM
  #42
98Camarod's Avatar
I pulled the 6 k member bolts, unbolted the sway bar from frame, unbolted the shocks, and spindle. The only thing that is holding the k member are the ps lines. If I would have did it all at once it would have been quick. But I was trying to get the oil pan out with as little work as possible and kept trying to get it out. So I still ended up having to do all of that. Some people say that they can get it out by just unbolting the 6 bolts, I couldn't. I jacked the motor and trans up and I still couldn't wiggle the bitch out. I'm still painting today and I'm waiting on some stuff to dry. We'll see how it turns out. I'm clearing everything so hopefully that will help.
Old Oct 12, 2008 | 10:02 AM
  #43
mthegodfather's Avatar
Very nice progress.
Old Oct 12, 2008 | 10:45 AM
  #44
98Camarod's Avatar
Today is my last day of leave so the progress will pretty much stop until weekends.
Old Oct 12, 2008 | 12:54 PM
  #45
Monello's Avatar
Where are you going to be putting the fans? Noticed that you added some coolers in front of the radiator. Did you push the radiator forward so you can use the stock fans?
Old Oct 12, 2008 | 01:21 PM
  #46
98Camarod's Avatar
I'll probably have to put the coolers on the other side and put the fans right there. I have more room now because I took out the a/c condenser.
Old Oct 12, 2008 | 03:45 PM
  #47
98Camarod's Avatar
For those of you running the radiator upright, what size radiator did you replace it with?
Old Oct 12, 2008 | 11:48 PM
  #48
candlelit's Avatar
all I can say is... AWESOME! going to be watching this as it progresses have fun with it!
Old Oct 13, 2008 | 06:14 PM
  #49
98Camarod's Avatar
The mounts didn't come in until late this evening, but I got em in and got everything bolted back up. We had another day off because of Columbus day so while I was waiting on the mounts I did some cleaning underneath and drilled and tapped another hole in the pan just incase there wasn't enough room. I put a new gasket on and got that all bolted up. Moved my coolers and mounted them. And by the looks of that picture I guess I need to touch up the inside there. Little less progress than I wanted today, but what can you do?
Old Oct 14, 2008 | 01:46 AM
  #50
red90cobra's Avatar
looks good so far. i did some work today too. looks like it'll the drain will work with that 90 you got on there. make sure you do your feed and drain line before putting on all the crossover and dp. it's a tight squeeze. and a pain to get to.
Old Oct 14, 2008 | 06:16 AM
  #51
98Camarod's Avatar
Probably a good time to put the steering linkage in too.
Old Oct 14, 2008 | 11:25 AM
  #52
headed-ws6's Avatar
This makes me wish I had all my stuff to do my turbo build. Good work though looks great
Old Oct 15, 2008 | 02:11 AM
  #53
KissMySSo1's Avatar
With the ebay setup has anyone had any problems with the passenger header v band flange hitting the bellhousing?
Old Oct 15, 2008 | 06:16 AM
  #54
98Camarod's Avatar
It doesn't hit it, but its close. I'll be seeing if it hits with the clamp on when I put that on.
Old Oct 15, 2008 | 08:20 AM
  #55
Rickys S/C Z28's Avatar
nice man good luck with this build!
Old Oct 15, 2008 | 09:30 AM
  #56
Monello's Avatar
Mine hit on the passenger side. Had to grind down the V-Band a little bit.
Look up my build thread, theres many pics on it.
Old Oct 15, 2008 | 01:01 PM
  #57
red90cobra's Avatar
Yes it does hit.
Old Oct 15, 2008 | 01:06 PM
  #58
Turbo Tech's Avatar
Make sure your oil drain is pointed straight up
Old Oct 15, 2008 | 01:32 PM
  #59
98Camarod's Avatar
Have the 90 going straight up? I don't know what kind of fall I'm going to have. I haven't had a chance to mount the turbo yet. I just had oral surgery today and I'm in some pretty nice pain.
Old Oct 15, 2008 | 01:52 PM
  #60
Monello's Avatar
Having the 90 go straight up is impossible with this setup unless your running a pump.
Do NOT attempt to hook up the steering linkage until everything is bolted up except the downpipe from the turbo.
You need to slide the rear downpipe up over the kmember, then bolt up the steering linkage. Then you can connect the downpipe from the turbo to the other downpipe.
