Another ebay build
Old Oct 15, 2008 | 02:00 PM
  #61
98Camarod's Avatar
Originally Posted by Monello
Having the 90 go straight up is impossible with this setup unless your running a pump.
Do NOT attempt to hook up the steering linkage until everything is bolted up except the downpipe from the turbo.
You need to slide the rear downpipe up over the kmember, then bolt up the steering linkage. Then you can connect the downpipe from the turbo to the other downpipe.
Will do. Atleast now I have some direction I have to get some more wrap before I can continue.
Old Oct 15, 2008 | 09:15 PM
  #62
redramair98's Avatar
i saw this kit on ebay, not to but in the threaed but has anyoen got there car together and runing with this kit
Old Oct 16, 2008 | 06:58 AM
  #63
98Camarod's Avatar
There are quite a few people. I know Monello has his together, but his trans is spent.
Old Oct 16, 2008 | 10:12 AM
  #64
98Camarod's Avatar
I'm recovering from this oral surgery so I can't do anything yet. I did get a package though.
Old Oct 18, 2008 | 09:34 AM
  #65
98Camarod's Avatar
I've got the griffin radiator coming and some 12" electric fans.
Old Oct 20, 2008 | 08:17 AM
  #66
98Camarod's Avatar
I got the crossover mounted yesterday and got the feed line fed through.
Relocation bracket should be arriving shortly along with the fans and radiator. I still need to sell this turbo
Old Oct 20, 2008 | 11:20 AM
  #67
Hibs's Avatar
what ebay kit is this?
Old Oct 20, 2008 | 12:18 PM
  #68
98Camarod's Avatar
The one that comes with the intercooler and is pictured on the red carpet.
Old Oct 20, 2008 | 05:07 PM
  #69
98Camarod's Avatar
Got some more stuff done. The alternator relocation kit came in, got that installed. Radiator came in, got it cut out and made the bottom retaining brackets. The zip ties are not permanent
Old Oct 20, 2008 | 05:18 PM
  #70
Pat-Man's Avatar
PM me who's alternator relocation bracket that is if you don't mind. Looks good.
- Patrick
Old Oct 20, 2008 | 05:35 PM
  #71
98Camarod's Avatar
Sent you a pm
Old Oct 21, 2008 | 12:07 AM
  #72
red90cobra's Avatar
your moving along. you still got to bolt that alternator bracket on for that idler. or make your own.
Old Nov 1, 2008 | 12:04 PM
  #73
98Camarod's Avatar
I got the radiator mounted, fans mounted and wired up, and got one of the ps lines ran. I have to wait until I get the dp in to see where I'm going to route the other line.
Old Nov 1, 2008 | 12:34 PM
  #74
WS6HUMMER's Avatar
Nice build, your doing a really clean job man!
Old Nov 1, 2008 | 12:42 PM
  #75
98Camarod's Avatar
It's not like someone I know's but its alright I wish I could weld like you and I'd have a much better setup
Old Nov 1, 2008 | 05:05 PM
  #76
OUTLAWZ RACING's Avatar
What stage zip ties did u use? Thats a good ideal for a light weight mod! JK !!! Hey could u pm me the fitting size for the power steering lines.
Old Nov 1, 2008 | 05:59 PM
  #77
98Camarod's Avatar
https://ls1tech.com/forums/forced-induction/367551-stainless-braided-power-steering-lines.html
Got them all from here. I'm not sure, but when I was dropping my k member they held up the rotor and a arm. So they must be alright.
Old Nov 18, 2008 | 04:37 PM
  #78
98Camarod's Avatar
It's been a while since I posted. I got some done. I got the coil relocation brackets mounted, turbo mounted, all the hot parts on, and got the gauges hooked up. I also picked up a new hood. Hopefully I'll get quite a bit done this weekend. It was the wifes birthday last weekend so I didnt do anything.
Old Nov 18, 2008 | 05:18 PM
  #79
Monello's Avatar
What is taking you so long to finish this?!!!
lol jk. Looks good, reminds me of my build.
Old Nov 18, 2008 | 05:24 PM
  #80
98Camarod's Avatar
I go to the nuke school and I get up at 5 and get home around 4. No real daylight to do the work until the weekend. Did you do a 2 bar setup or do you still have your maf and stock map?
