Custom Twin Turbo
Custom-built 60mm Hybrid Turbocharger
Custom-built mandrel-bent Jet-Hot "Sterling" ceramic-coated exhaust headers
Custom-built mandrel-bent Jet-Hot "Sterling" ceramic coated turbo kit tubing
TIAL 38mm aluminum billet wastegate
Bosch blowoff valve
Custom-built aluminum high-efficiency air/air Intercooler
8 upgraded fuel injectors
Silicone reinforced intercooler hoses
Stainless steel high torque T-Bolt hose clamps
Stainless steel V-Band clamps
S&B conical intake air filters
Custom-built exhaust to cat-back piping
Computer program upgrade
How does it look? What questions should I have for him?
Thanks guys
Some questions for them
1) Is the manifold going to be equal length tubes or a log manifold? Stay away from the log if possible.
2) What are they using for boost control. They maybe relaying on the wastegate spring. I would install and aftermarket electronic boost controller. Helps build boost faster, holds boost more steady, and also has built in fail safes if something goes wrong.
3) Are the oil returns from the turbos going to be gravity feed or are they going to use pumps?
4) Have they made other turbo kits successfully already? Any one can weld up a turbo exhaust manifold and say it’s a custom kit. If they don’t know what they are going it will not perform well.
You said it was a twin turbo set up so I am assuming there will be 2 Custom-built 60mm Hybrid Turbochargers,2 TIAL wastegates, 2 air/air Intercooler
mark
ALso i had my piping cermic coated, inside and out. If it will flake on the inside, it will also be flaking on the outside, and something would be wrong, from to much heat. that coating can really stand up.
I'll definitely check out that book.
Logs will work just fine for most applications.
But a pair of log manifolds for a twin setup will be cost effective, and make more power than the average person needs
The inside of the piping will see much more heat than the outside. The whole purpose of coating the inside is so the heat is not absorbed by the piping and stays inside. Just have it coated by a reputable place. May want to get in writing that it will not flake off on the inside and that they would be responsible for the damage to your turbo if it does.
mark
