347" question...
Old Oct 10, 2008 | 12:32 PM
ELMiN8oR's Avatar
Default 347" question...
Just had broken rod not to mention a broken Block
now I'm building a new forged 347"
My question was in 347 on D1SC set up running 12 PSI on pump gas, also will my stock heads can handle that much boost?
will it go over 600 rwhp ?
Setup is:
forged 347 Compression will be 9.5
stock ported heads
226/228 .585/.588 on 113+3 LSA
Custom Fuel system
Stage III spec clutch and Fidenza flywheel
Stock rearend
here are some pics of my old engine
just look what happend to my rod
Old Oct 10, 2008 | 12:44 PM
98transguy's Avatar
140+RWHP is a good estimate depending on supporting mods
Old Oct 10, 2008 | 10:46 PM
Interlizer130's Avatar
that stock rearend isnt gonna hold up for long
Old Oct 10, 2008 | 11:03 PM
venom ws7's Avatar
12psi should get 600rwhp I have friend got 465rwhp with 3.9psi with STOCK Heads unported too.
I may suggest changing the cam too.
Depends on how he drives the car.
Old Oct 11, 2008 | 10:50 AM
Rickys S/C Z28's Avatar
i think you are in the ball park but im not for sure im still waiting to get mine tuned
Old Oct 11, 2008 | 01:06 PM
tomz28's Avatar
yes i made 650+ rwhp on 12psi on a 346
Old Oct 11, 2008 | 01:08 PM
bboyferal's Avatar
OMG, carnage.
Old Oct 11, 2008 | 01:12 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
i think so.. Be sure to get a good blower can like the SC2 from speed inc or EPP also sells some good ones as well. I made over 600rwhp on 14psi on stock 6.0L heads with 9.5ish compression on my old 347ci combo..
Old Oct 12, 2008 | 04:17 PM
ELMiN8oR's Avatar
The car will be driven only on weekends
I will stay with this cam bro cause I have a good felling on this one
wow thats a nice number; what was your supporting mods n the 346?
Old Oct 12, 2008 | 06:13 PM
tomz28's Avatar
317 heads
04 ZO6 cam
head studs
ARP rod bolts
LS6 intake
twin 255 walbros
60lbs injectors
Old Oct 13, 2008 | 11:33 AM
ELMiN8oR's Avatar
317 heads
04 ZO6 cam
head studs
ARP rod bolts
LS6 intake
twin 255 walbros
60lbs injectors
very nice bro
I got the same set up except heads and cam
Thanks for the info
Old Oct 13, 2008 | 01:25 PM
dschmittie1's Avatar
605rwhp
forged 347
241 casting that I did a little clean up work to
224/232 .595/.583 114
9.5:1
60# injectors dual intank walboro pumps
1 7/8 kooks
FMIC
around 12psi
Old Oct 13, 2008 | 01:41 PM
ELMiN8oR's Avatar
nice numbers bro
I'm really happy with the numbers I've seen so far
