fueling needs for 800
Old 11-09-2008, 09:24 PM
youguessit's Avatar
Default fueling needs for 800
I need to know what kind of fueling setup i should go with on my 02 a4 camaro. It is about to be making 7-800 rwhp. I know ill have to replace my pump and fuel lines and fuel rales.... what size line, where do i get it and is there a resonably priced kit? someone let me know... oh and not sure if it will be turbo or procharger... what size injectors? (forged 346)
Old 11-09-2008, 11:39 PM
nahasapeemapetalon's Avatar
Checky out Nasty performance. They are a sponser on here, you will be dealing with Nate. I went with magnafuel inline through him. Some go inpump, i wanted one system that would handle enough for no matter what i did. This may be overkill but if you want to run e85 id consider it. I think my supply line is #8 and return #6 magnafuel pump 4301... Nasty fuel rails and magna fuel regulator.
He is good to work with and very helpful look him up.
Old 11-10-2008, 02:08 AM
FICINJECTORS's Avatar
For injectors for that much HP on forced induction I would reccomend our 83lb Siemens injectors.
They are brand new, high impedance so you can run the stock ECU. And I can get them with the correct connectors for your car.
I can do them flow matched for $90 each
Old 11-10-2008, 10:04 PM
youguessit's Avatar
I was hoping for some in tank pumps and or something thats not visible like the one pictured above... live in houston that pump would disapear if it was in plain view like that.
Old 11-10-2008, 10:13 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
I build dual intank setups for that application. You will never know they are there.
Old 11-10-2008, 11:30 PM
youguessit's Avatar
How much for kit including pumps and braided fuel line and regulator
Old 11-11-2008, 08:31 AM
youguessit's Avatar
Do you have any pictures of what comes on the kit?
Old 11-11-2008, 12:00 PM
No Juice's Avatar
Old 11-11-2008, 08:48 PM
LS1TECH Sponsor
Prices vary based on options, which can be found on my website.
I sell the pump kits separately or with a complete fuel system including lines, fuel rails, filter,braided -8 supply/-6 return & all fittings.
Feel free to call me for more info.
Old 11-12-2008, 02:27 AM
ramairws6's Avatar
Give Lonnie a call and he will take care of ya! I'll get those pictures to ya by the end of the week Lonnie..........and thanks for all your help!! Traver
