I need pump install help asap!
Thanks
Justin
Any ideas as to why i am seeing a lower psi?
justin
The Racetronix kit is not supposed to come out the bottom of the bucket... it goes inside the bucket. The venturi & factory bottom sock on the bucket are supposed to remain intact.
I do not recommend you use the kit without the harness.
Justin
Does your bucket have any holes made in it?
Is the jet-pump still in the bucket along with the two checkvalves in the bottom?
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
The bucket is not cut, there is a round opening on the buttom of the bucket, where i would assume the second filter sock attaches to the bucket.
I am not sure what the jet pump is, but if this clears things up, before i slide the pump assembly into the bucket, there is nothing in the bucket
From what i have gathered I am missing one filter sock that goes on the buttom of the bucket, is there something else that i am missing? Is there something that helps bring the fuel into the bucket?
Justin
Justin
>WEB SITE<
So, where the venturi system is i just have a hole, not one that looks like it was cut, but just that the venturi system is missing. IS it possible to get a replacement venturi system or do i need a new bucket completely. Also, does the second filter sock attach to the buttom of the venturi system?
Lastly, where can I get a replacement venturi system or a replacement bucket, i checked autozone and they coudlnt' find anything with that name and they didn't carry a replacement bucket.
Justin
Justin
The brown Nylon mesh sock goes on the bottom of the jet pump's inlet.
There may be damage to the Racetronix pump now since it was run without a functioning bucket assembly.
A word of wise to the masses reading this thread. Do not move ahead with your pump installation or attempt to run the pump if there is even the slightest thing that is missing, out of place or just does not seem right. It can cost you a pump or even worse a motor. When in doubt contact a Racetronix dealer or support@racetronix.com.
>WEB SITE<
justin
Good deal for new unit.
>WEB SITE<
