New Ford 80#High Imp injectors
#41
i have a set of these, cake walk to tune, idles perfect. actually i had them up to 96% duty cycle so far. they will out flow twin walbro pumps. i know im having problems keeping the pressure up. these injectors at 80% are making north of 900rwhp. im upping the boost to see where their limit is. should know soon enough.
fuel setup is twin walbros 340s, magnafueler y fitting, -8 aeromotive feed, to twin aeromotive rails. proseries aeromotive regulator.
#42
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#44
they are to long for a ls3.. you would have to space the rails to high and the injectors are splayed so as you raise the rail you loose the alignment, plus the plug might need an adapter unless you got the ford 80's. We use the ZR1 injector and modify it to flow 80, its then its a direct fit... If you are using a LS1 computer we have all the tables configured for EFI live. We have had great success with this combo over the siemens
