Were can i get a locking gas cap
Old Oct 22, 2003 | 02:11 AM
LS1FIRE's Avatar
Default Were can i get a locking gas cap
Do yall know were i can get a locking gas cap for a 98 trans am. i just cant find them anywere.Do they even have a locking gas cap for 98 to 02 f bodies?
Old Oct 22, 2003 | 04:54 AM
blk~2000~Z28's Avatar
Default Re: Were can i get a locking gas cap
Locking gas cap
Try this link, someone posted the GM part number and price.
Old Oct 22, 2003 | 11:12 AM
slow's Avatar
anybody know if there is a locking gas cap for the 98's as they use a different cap than the 99-02 from what i have read.
Ryan.
Old Oct 22, 2003 | 11:24 PM
LS1FIRE's Avatar
Yeah i also have a 98 I wish i knew were to get one.
Old Oct 26, 2003 | 02:07 PM
Eiyse98ls1's Avatar
from what ive read. there isnt one that fits our 98's.. ive tried several but none fit. ive also ordered one through gm parts #'s and that didnt fit.. i think us with 98's are SOL
Old Oct 26, 2003 | 02:33 PM
Scalpel's Avatar
Could the 98's swap out the portion of the gas fill for the same portion on the 99+ so one could use the locking caps?
Old Aug 27, 2004 | 12:28 PM
brianwetzel's Avatar
I was wondering the same thing. I really want a locking cap for my 98 but it is not available from any supplier. Has anyone done a successful 99+ locking cap merge with the 98 lower section?
Old Aug 27, 2004 | 06:21 PM
LS1FIRE's Avatar
98 lockng gas cap problem was solved. Buy acdelco part number# 2266-0006 And grind down the tabs a little and it should fit perfect.
Old Aug 31, 2004 | 10:21 AM
MIGHTYMOUSE's Avatar
as above.. it will work, just cut it down some.. i got mine from NAPA 703-1643
Old Sep 7, 2004 | 10:56 AM
I noticed the original 98 cap does not have the vent in the center like the 99+ does. Does anyone know why the difference? Will using a vented cap cause problems on the 98 car? Thanks, Brian.
Old Sep 8, 2004 | 01:17 AM
LS1FIRE's Avatar
I wouldnt worry about the air vents just buy the part number above and grind down the triangle parts on each side and it should fit perfect.
Old Nov 2, 2004 | 12:22 AM
LS1FIRE's Avatar
Locking gas cap problem solved. http://www.ls2.com/forums/showthread...ocking+gas+cap It was solved on the other forums awhile ago. just wanted to post the link.
