round silver thing on fuel rail
i would not reccomend removing it.
but then again, if i had your setup, (and money no object) i would have a returnstyle fuel system, and vac/boost referenced rail mounted regulator as well.
side-side imbalance at higher injector flows. I did a
search on "fuel pulse damper" & variations and came
up with squat, although I know I've seen it discussed.
Honestly, I think you're best to get aftermarket rails if you're at the power level that's maxing out the factory ones.
I don't believe a dampner is necessary (like you said, you don't have one with aftermarket rails) but gutting the thing sure caused some bad results for me.
Nate
