FP and fuel level
Old Nov 22, 2003 | 11:44 PM
bigSS's Avatar
Default FP and fuel level
If your running really low on gas, will this affect fuel pressure? I have a Racetronix kit for my C5.... tonight while I was using the a 150shot for a race, I felt some hestiation. Is it possible I was running low on fuel pressure?
Old Dec 19, 2003 | 07:44 PM
emarkay's Avatar
not low pressure, prob air bubbles!
NEVER get low on fuel, the fuel is the heat sink for the in tank pump!
Old Apr 18, 2005 | 11:51 PM
screamin00ss's Avatar
bringing this one back from the dead, was doing a search for air bubbles and found this post...i just installed a walbro 255 and it has been running decent but today when i cut it off i noticed a sound in my fuel tank that sounded like air bubbles....is that what this is and if so how can i fix it?
Old Apr 19, 2005 | 08:06 PM
nobody can help?
Old Apr 20, 2005 | 04:56 AM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Try to avoid running the tank dry. The fill bucket can help but only to a point. If you are making some good HP you could end up sucking the bucket dry as the venturi system can not keep the bucket full under WOT and it needs time to help it recover. This can also damage your pump if it is repeated on a regular basis.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old Apr 20, 2005 | 05:29 PM
come on guys....please? lol
Old Apr 21, 2005 | 05:52 AM
Racetronix's Avatar
LS1TECH Sponsor
So you cut a hole in your bucket and installed a generic Walbro 340?
__________________
>WEB SITE<
Old Apr 21, 2005 | 05:54 AM
Racetronix's Avatar
LS1TECH Sponsor
... and lubrication. We all know how important that can be.
__________________
>WEB SITE<
Old Apr 22, 2005 | 12:31 AM
sorry let me clarify, i installed the walbro 255 kit from tsp and it runs fine, however when i cut the ignition off i could hear the bubbles (or what sounded like it) in the gas tank
Old Apr 22, 2005 | 04:28 AM
GTS346's Avatar
If it does it for a few seconds after switched off its probably just the return fuel being dumped back in the tank.
The air bubbles are what happens when the engine surges from lack of fuel, eg going low on fuel or around a long corner where the pump doesn't pickup fuel it pumps air as thats all its picking up, this makes the car surge (fuel surge).
Old Apr 22, 2005 | 05:57 PM
dynocar's Avatar
The fuel in the return line is often very bubbly due to the rapid drop of the fuel's pressure during its exit from the fuel pressure regulator. The best fuel systems keep the outlet of the return line away from the pickup and keep the exit submerged in existing fuel or we create even more bubbles to be picked up and sent to the injectors. Also, keeping the return exit submerged helps to minimize in tank fuel vapor which makes a much less of a tank explosion if in an accident.
