New Injectors
I just picked up 8 LS3 Flow balanced modified injectors in the tall style to clear my FAST. These injectors are the NEW Bosch Gen.4 injectors that flow 42 LBS at 3 Bar or 50 LBS at LS rail pressure of 57psi.
I'm pysched as I didn't want to run old ford technology (green top) in my GM!!!
I will be able to grab the 06 Corvette injector tables and use them in EFI Live as a good starting point for setting my IFR tables.
John was a wealth of information at Fuel Injector Connection, LLC
Tel: 770-888-1662
Photo of the New Injector next to the LS1 injector.
![](http://i689.photobucket.com/albums/vv257/BRD-PREY/Injector.jpg)
Ed
Tel: 770-888-1662
Ed
The cap is a machined extension that makes the shorter 4th gen injector as long as the earlier 3rd gen injector.
The improvement comes from the new 4th Gen Bosch design. The green top ford is like a 20+ years old design. A lot of improvements have come along in 20 years.
Ed
Ed
Ed
Ed
Banned For Creating Troll Account t1_ID_MIKE
That PDF says "Easy tuning as it is the same coil as the stock injector!"
Does this imply that the injector dead time data in the ecu does not have to change with any of these different sizes since it's the same coil?
Hey I’ve got a turbo ls6 and thinking about making the switch to e85… Figure these 90lb bosch pieces you’ve got should do the trick. Went through this article and found I need a bunch of injector data to make sure fueling is correct and I can get a good tune (using hptuners). Not sure exactly what all of it is, but this guy works for GM so figure he obviously knows his ****. Anyways, you said you have these for use with stock pcm, so hoping I can just plug in your data for these and start running some alky!! Let me know!
BTW, I think these are the tables I need data for…
Cool, so they come with dead times vs. manifold vac then? What about the flow vs. mani vac, short pusle adder, and min pulsewidth data? I wouldn't want to just enter the data from the 06 vette like BRD-PREY mentioned since the article makes it clear changing flow can skew all those other numbers and get everything outta whack...
all we give you is the dead time, We are not tuners and we don't represent that we are. So how is everyone changing injector sizes with minimal problems, There are countless LS1's using the Siemens 60. There is no data that comes with that injector. These guys have installed these Bosch Injectors and had great success. Maybe one of them can chime in. Chuck COW, Cory, Henderson Motorsports, Ron, Vengence, Julio, Cartek. Chris, xtreame Motor sports, Frazier, Speed Inc. Carmine, vette doctor, and over 60 other shops across the country including Hemi guys and Ford guys that have put these in. No Injector that I know of comes with any data. But since this is the identical injector that came with the ls2 and up it would be conceivable that tuning these using the resources and/or expert tuning shops in the business would be easier than using an injector that has no resemblance to the factory injector.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Tuning most of his injectors is as simple as changing flow rate, especially when the coil or body is the same as what you started with.
While tuning injectors can be tricky if you don't start with the right core and body, Jon usually has an option for just about everyone that minimizes tuning and expense.
I'll never buy another injector anywhere else and you shouldn't either!
Stay TUNED!
Chuck CoW
Thats what I said, I would do. Us the 06 Corvette as a starting point. I then need to adjust for the volume increase that will result from taking them from 36 to 42 lbs.
Ed
Or you could go with Injector Dynamics injectors. They are the only aftermarket injector supplier that includes ALL the necessary data for both Ford and GM computers. [removed non-sponsor link]
