1000+ wrhp fuel pumps help
Hi All ,,
Now i'm installing my fuel system , injectores , fuel pumps and every thing in extrem performance garage in kuwait ( The best garage in kuwait ) do by the top tuner faisal dashti
Now , i want to know does the BOSCH 044 Inline pump and Walbro
255L with 96# Injectors handel more than 1000 rwhp ??
please calculate and tell me as soon as you can guys ,,
stay tuned with my big S91 kit and you will see the Spool
Hi All ,,
Good luck.
Because when i put another bosch 044 the pump sound will be loud ,,
so please i want you to tell me how many rwhp can i get with my setup without leaning out ??
THanks
THanks
No it won't.ECS makes a similar system and say it's only good for 800 RWHP.If you are mounting the Bosch pump externally you should activate it on a Hobbs switch to avoid the noice and heating up the fuel.Don't chance it.Add another Bosch.
http://www.eastcoastsupercharging.co...%20System.html
https://ls1tech.com/forums/fueling-i...ump-chart.html
Call Lonnies for the right setup.
It should do about 1000-1100rwhp along with that Walbro. as long as both pumps are parallel and as mentioned trigger the Bosch with the boost.
ECS kit mentioned is rated at 800 to be safe because it uses a factory fuel pump not a Walbro.
