Spectra fuel pump upgrade
Trying to determine if the pump output will be adequate for my HP application... My question is, if you regulate the pressure of this pump down to 58 PSI (with vette filter/ regulator) will the output still be 50-60 GPH?
If no, do they make a direct fit pump upgrade for my application? I will be in the 450 RWHP range.
Thanks in advance..
The new cam is a 234/246 setup so it a lot more aggressive.
Are they as good as a modern fuel tank in a new car, no, do they work for hot rods, yes.
Thanks,
Chris
