ZR1 fuel pump
Old 03-17-2011 | 01:55 AM
GREG O.'s Avatar
Question fuel pumps
Originally Posted by Nasty N8
The ZR1 uses 2 pumps electronically controlled. We have built/installed several hundred dual Walbro kits and have had ZERO failure its all about the install.
Have u ever installed duals on a Cadillac CTS-V...I here it is a pita to install any different type pump in my V. because of the way the tank is engineered.
Old 03-17-2011 | 02:13 AM
LilJayV10's Avatar
Originally Posted by hellbents10
I have never had any troubles with Genuine Walbro fuel pumps. I have only heard of problems with the over seas knock off pumps. That problem can be solved by not buying them on Ebay, and spending a few more $$$ to get them from a reputable source.
This^^^
Old 03-17-2011 | 03:16 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
I do a dual intank kit for the early CTSV's. Not exactly easy to build, but I have done a few of them. Give me a call if you want to discuss.
Old 06-11-2011 | 12:24 PM
Toxic-Evo's Avatar
with the Dual ZR1 pump go in a normal C6?
Old 06-11-2011 | 03:10 PM
Mr. Fuel Pump's Avatar
The C6 era ZR1 only uses one pump in the drivers side tank, not dual pumps; and it is not compatible with a base C6 electrical system
Old 06-11-2011 | 06:01 PM
GREG O.'s Avatar
Question fuel system
why can't u just drop a 20gal. fuel cell in the trunk and run your pump or pumps..It sounds a lot easier....also couldn't u still run the stock pump in the stock tank [ u would have almost 40 gal. of fuel and added pressure and insurance] yes or no
Quick Reply: ZR1 fuel pump
