High Flow LSx Injectors All Flow Matched
We now have available GM factory injectors for LS1, LS6, LS2 and LS3's that are flow matched and upgraded to support 750 + horse power applications.
LS2 60lbs:
$325.00 shipped - lower 48.
Perfect for any LS2 car in need of more fuel with no adapter's needed, will also work with LS1 and LS3 but will require either spacers or injector connector adapters. Should be able to support up to 750 + hp. The 60lbs is based on 3 bar, or 43.5 psi. where as LS cars run 4 bar at 58psi, these are realistically about 70 lb injectors. Often times we can provide the adapter kit based on your specific application.
LS3 60lbs:
The 60lbs is based on 3 bar, or 43.5 psi. where as LS cars run 4 bar at 58psi, these are realistically about 70 lb injectors. Often times we can provide the adapter kit based on your specific application. Perfect for any LS3 car in need of more fuel with no adapter's needed, will also work with LS1 and LS2 but will require either spacers or injector
LS1 42lbs:
Upgrade again based on 3 bar, these at 58psi are obviously greater than 42lbs as well.
White GM LS1/6:
Upgraded from 36lb to 48 - These are very much like the green top Ford SVT injectors but with a much better flow pattern that is much better to tune.
LS1 42lbs:
White GM LS1/6:
LS1 42lbs:
White GM LS1/6:
For Sale Link:
https://ls1tech.com/forums/lsx-parts...injectors.html
Thanks
Dan
Fasterproms
Labels 0 5 10 15 20 25 30 35 40 45 50 55 60 65 70 75 80
Flow 40.923 41.233 41.543 41.729 41.977 42.287 42.473 42.783 42.969 43.279 43.466 43.714 43.900 44.210 44.396 44.706 44.892
https://ls1tech.com/forums/sponsor-s...w-matched.html
