Nitrous/fuel question
Hey guys, I got your basic fuel/nitrous question. Here's the facts
1. 04 ZO6
2. LS6, 6 speed
3. good size cam/and full bolt-ons
4. about 430 to the rear wheels=all motor
5. stock fuel system
So heres the question, I want to run a 150ish wet shot. But I think my fuel system is close to maxed. I was thinking a walboro 255, but I don't think it could support 625ish RWHP. And I don't want to cut it that close. But I also don't want to spend a fortune on a nitrous fuel system. What is appealing about nitrous is it initial cost per HP. If I'm going to spend thousands on custom fuel systems and a kit then I would consider other avenue's.
Thanks......
Maybe It wasn't clear, I'm looking for advise on a fuel fix for a 430ish N/A with 150ish wet shot. Total 575-625ish RWHP. Has to be streetable.
But if I can't make it work from the car tank then I may do a stand alone with a 1 gallon cell up front. And thats a whole nother bag of worms.
Series pumps are not the way to get volume... they should be run in parallel.
Feel free to call if I can help you with a system for your car.
The C6 requires a bit of work to make a dual pump work properly.
Also the 340 pump is not huge in size, it is the same diameter as any other 255 pump. It also isn't a 340lph pump, but a high pressure 255, hence the reason it is the same size as all the others.
