Please help.....
Old Feb 25, 2010 | 12:14 AM
sapo84's Avatar
Default Please help.....
so im getting ready to fire up my first LS engine build. I put in a 11.5 compression stroker kit along with some dart heads, my question is: since its a lot more compression than normal, can i fire it up like that or let the tunning shop start it for me? thanks for your answers....
Old Feb 25, 2010 | 12:25 AM
waterbug1999's Avatar
Id say go for it, just watch oil pressure.
Old Feb 25, 2010 | 12:28 AM
sapo84's Avatar
even though im still running the stock injectors?
Old Feb 25, 2010 | 12:30 AM
yea...
If you went to bigger injectors and didnt change anything in your tune, I doubt it would start, or if it did it would idle/run like crap.
When i did my ~11.5.1 H/C/I I drove it over to the place to get it tuned on stock injectors then added the new ones in their shop.
Old Feb 25, 2010 | 12:41 AM
sapo84's Avatar
ohh ok....sounds good.....so you also thinks its safe to break in the cam like that?
Old Feb 25, 2010 | 12:44 AM
I would be very weary about doing any kind of WOT or hard pulls until you get it tuned.. Starting it up and checking oil pressure, leaks, etc it should be fine. If it runs decent then go take it for spin.
What size cam you go with? You running milled heads and smaller gasket?
Old Feb 25, 2010 | 12:47 AM
sapo84's Avatar
ok ill do that then. thanks a lot waterbug your a big help
Old Feb 25, 2010 | 12:50 AM
oil pressure is the big thing, the little o-ring by the pump can be a PITA to get right the 1st time.
Old Feb 25, 2010 | 12:55 AM
sapo84's Avatar
the o-ring?.....its the one going to the pick up screen right?
Old Feb 25, 2010 | 12:56 AM
tube to the pump..
Old Feb 25, 2010 | 12:59 AM
sapo84's Avatar
Originally Posted by waterbug1999
tube to the pump..
yeah i remember that one....its on....
