30# SVO Red Top injectors big enough?
Im running the SVO red top 30# injectors on my current setup. They are just above 36# on our fuel pressure. With the new setup im going with im going to have around 450 at the wheels and 600 with a wet shot.
I know the injectors big enough to support my NA HP but since the nitrous kit is a wet kit do i need to worry about upping my injector size yet?
thanks guys
thanks guys
thanks guys
thanks guys
Hey man i was hoping you chime in. Ya i already have the racetronics pump and hot wire kit. Thanks for the info and when i build my stroker i will be getting some big killer injectors from you for sure
![Headbang](https://ls1tech.com/forums/images/smilies2/headbang.gif)
